- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] type classes and conversion tactics
- Date: Thu, 15 Apr 2010 11:07:38 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=TR7Ri9oU+DTAJaI8g90N+RTMaA/wsyzwqBVrgO7QiZ2fVEiYSy5r/HIJR48KmhRSap vGrRG28eUuegrpAYanRokIDGeuR5V5UOydW5j0AU6n05Loq9UEbtcjmqSegL0cFSXXC4 Cq5HaPIZMzh4T5afqfG1mY8KZOz6l4yylslfE=
On Thu, Apr 15, 2010 at 9:46 AM, Matthieu Sozeau
wrote:
> There are many workarounds for that situation. One is to prove the
> equations
> of [is_lt] and rewrite with them to simplify expressions, ensuring the best
> control over the form of terms.
That's a principled way to do things, but impractical unless these
equations are generated automatically. I forget, wasn't there some
newer facility that does generate these equations automatically?
The other suggestions are partially helpful, but let me give a
slightly more complex example.
<coq>
Inductive A: Set := A0: A | A1: nat -> A.
Inductive B: Set := B0: B | B1: A -> B -> B.
Class Summable (X: Set): Set := { sum: X -> nat }.
Instance nat_Summable: Summable nat := { sum := fun x => x }.
Instance A_Summable: Summable A :=
{ sum := fun a =>
match a with
| A0 => 0
| A1 n => sum n
end
Fixpoint sum_B (b: B): nat :=
match b with
| B0 => 0
| B1 a b1 => sum a + sum_B b1
end.
Instance B_Summable: Summable B := { sum := sum_B }.
Lemma foo:
forall (a1 a2: A) (b: B),
sum a1 = sum a2 -> sum (B1 a1 b) = sum (B1 a2 b).
Proof.
intros ? ? ? H.
</coq>
At this point, I would hope that "simpl" would leave me with --
sum a1 + sum_B b = sum a2 + sum_B b
-- or even better:
sum a1 + sum b = sum a2 + sum b
Instead, "sum a1" and "sum a2" get fully expanded into their primitive
definitioins. (Obviously, I can't make "sum" opaque here before I use
"simpl".) Other than being difficult to read (imagine a much larger
program), I cannot use "rewrite H" after "simpl". Of course, in this
case, I can just use "simpl; simpl in H; rewrite H", but, more
generally, I may have a lemma that looks like H rather than a
hypothesis in the context -- and perhaps more importantly, the fully
expanded terms make it difficult to discover which lemma I want to
use.
It seems the situation can be partly alleviated by using an auxiliary
definition for "sum_A" as I did with "sum_B", in order to block the
reduction performed by "simpl". (I didn't really understand this
principal before I wrote my last email.) Maybe that's not too
troublesome, but it does make type classes a little more cumbersome
than they would be with better conversion tactics.
- Aaron
- [Coq-Club] type classes and conversion tactics, Aaron Bohannon
- Re: [Coq-Club] type classes and conversion tactics, Stéphane Lescuyer
Matthieu Sozeau
- Re: [Coq-Club] type classes and conversion tactics, Aaron Bohannon
- Re: [Coq-Club] type classes and conversion tactics, AUGER Cédric
