coq-club - Re: [Coq-Club] setoid_rewrite under binders
chronological Thread
  • To: Matthieu Sozeau <mattam AT mattam.org>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] setoid_rewrite under binders
  • Date: Sun, 25 Apr 2010 22:20:56 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=cggxhAD4ehU8bDFbBeLga1P7hni2xIdZykiB7BTwtTYsLjxLj6u1AacGnxWu1sZVXX D9avlt+OWN/RKdff/gRgqdj+5GJzN8Zfqd6EqyGPBhHRcgeinfLGWD1OTbu4TAISmYix ntWhPPt/DY4rMcWJV799L4A4qEsDD7ZBEuLuY=
On Sun, Apr 25, 2010 at 11:08 AM, Matthieu Sozeau
 wrote:
> Le 25 avr. 2010 à 09:52, Jianzhou Zhao a écrit :
>> Hi,
> Hi,
>> The code bellow was simplified to demonstrate the problem:
>> Parameter f : nat -> nat.
>> Axiom f_def : forall n:nat, f n = n.
>> Lemma L :
>>  forall n (eq:f n = n) (p:forall n, f n = n->Prop),
>>  p n eq=True -> n = 0.
>> intros n.
>>  rewrite f_def.
>> This last rewrite fails, because if f_def change (f n) to n,
>> eq changes its signature, not matching p's type.
>> The tactic 'pattern (f n)' fails for the same reason.
>> The binder (forall n,) stops rewriting.
>> Can setoid_rewrite solve this problem? It claims it
>> works under binders
>> (http://coq.inria.fr/refman/Reference-Manual030.html#toc165)
>> Coq > intro n. setoid_rewrite f_def.
>> Error: found no subterm matching 'f ..." in the current goal.
>> Coq > intros n eq p. setoid_rewrite f_def in p.
>> Anomaly: build_signature: not enough products. Please report.
>> I thought the default eq relation '=' should be also a well-formed setoid.
>> Is my case the problem setoid addessed?
> Indeed it claims to work under binders, but it's not possible in
> general to rewrite in hypotheses that are used in other hypotheses
> (the same limitation appears in the standard rewrite in most cases).
> As p's type would change after the rewrite, we would have to modify
> the [p n eq=True] hypothesis in some (as far as I can see) unknown way.
> Also, the only "relations" between [p : forall n, f n = n -> Prop]
> and [p' : forall n, n = n -> Prop] are heterogenous and currently
> rewriting expects homogeneous relations only (e.g, typeable as [relation
> foo]).
> The anomaly you got is now a regular error though.
Could you elaborate the definition of heterogenous relations?
Intuitively, we cannot simply show p can be replaced by p'.
p represents a proof of "forall n, f n = n -> Prop", and p' is a constructive
proof of "forall n, n = n -> Prop", they can be quite different.
We must show in any context where these proofs are manipulated,
p and p' are equivalent. Thanks.
> -- Matthieu
Jianzhou
