- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A question about declaration and definition
- Date: Wed, 05 May 2010 10:20:28 +0200
- Organization: ProVal
Le Wed, 05 May 2010 08:06:02 +0200, geng chen <chengeng4001 AT gmail.com> a écrit:
Hi everyone,
Recently, I need to develop a prototype in Coq. But I've met a problem, it
seems naive, but it is important for me.
Inductive prim : Set :=
A : prim
| B : prim.
Inductive comp : Set := list all.
Inductive all : Set :=
C : prim -> all
| D : comp -> all.
Is there anyway to define the 3 types aboves? Do I need to use some special
kinds of method to declare the type "all" in the front of the definition?
Thanks, best regards
Chen
There are mainly two ways to do this:
"Require Import List.
A : prim
| B : prim.
(*Inductive comp : Set := list all.*)
C : prim -> all
| D : list all -> all.
Definition comp : Set := list all. (* if you really need it *)"
and
A : prim
| B : prim.
C : prim -> all
| D : comp -> all
with comp : Set :=
| nil_comp : comp
| cons_comp : all -> comp -> comp."
In the first solution, you have access to all List library for comp,
but mutual induction will be harder
(test it, to understand what I mean;
you can also have a look or Induction Scheme in the Coq reference manual);
in the second case, you have to redefine all what you need on lists,
but mutual induction will be piece of cake.
In both ways, you should really take a look on the manual,
since induction being central in Coq
(brief history: Coq is named after CoC= calculus of constructions
but now uses CIC= calculus of inductive constructions),
it is rather well explained.
For an example of both uses:
Require Import Bool.
Definition prim_eq (p1 p2: prim): bool :=
match p1, p2 with
| A, A => true
| B, B => true
| _, _ => false
end.
Lemma prim_eq_lemma: forall a1 a2, if prim_eq a1 a2 then a1 = a2 else a1 <> a2.
Proof.
destruct a1; destruct a2; simpl.
split.
intros; discriminate.
split.
Qed.
1. boolean equality definition (without using "decide equality"); play with uncommenting...
(using Induction Scheme may ease things a lot;
there may also Coq functionnalities I am not aware of, or powerfull tactics,
but it is always good to do how things are really done)
Definition forallb2 {A: Set} (f: A -> A -> bool): list A -> list A -> bool :=
fix forallb2 (l1 l2: list A) :=
match l1, l2 with
| nil, nil => true
| a1::l1, a2::l2 => f a1 a2 && forallb2 l1 l2
| _, _ => false
end.
Fixpoint all_eq (a1 a2: all): bool :=
match a1, a2 with
| C p1, C p2 => prim_eq p1 p2
| D l1, D l2 => forallb2 all_eq l1 l2
| _, _ => false
end.
Lemma all_eq_lemma: forall a1 a2, if all_eq a1 a2 then a1 = a2 else a1 <> a2.
Proof.
induction a1; destruct a2; simpl; try (intros; discriminate).
generalize (prim_eq_lemma p p0); destruct (prim_eq p p0).
intros H; case H; split.
intro H; now injection.
(* now you are stuck *)
(* but before being really stuck, we can do some cleaning: *)
cut (if forallb2 all_eq l l0 then l = l0 else l <> l0).
destruct (forallb2 all_eq l l0).
intro H; case H; split.
(* and start an induction *)
revert l0; induction l; destruct l0; simpl; try (intros; discriminate).
split.
generalize (IHl l0); clear IHl; destruct (forallb2 all_eq l l0); simpl.
intro H; case H.
Abort.
Lemma comp_eq_lemma:
(forall a1 a2, if all_eq a1 a2 then a1 = a2 else a1 <> a2) ->
forall l l0, if forallb2 all_eq l l0 then l = l0 else l <> l0.
Proof.
intro EQ; induction l; destruct l0; simpl; try (intros; discriminate).
split.
generalize (EQ a a0); clear EQ.
destruct (all_eq a a0); simpl.
intro H; case H; clear a0 H.
generalize (IHl l0); clear IHl.
(*Qed.*)
Defined.
Proof.
fix 1 (* a trick, that makes you lose guardedness *).
(* exact all_eq_lemma.
Qed.*)
destruct a1; destruct a2; simpl; try (intros; discriminate).
generalize (comp_eq_lemma all_eq_lemma l l0).
Qed.
2. boolean equality definition (without using "decide equality"); rather straightforward
match a1, a2 with
| D l1, D l2 => comp_eq l1 l2
| _, _ => false
end
with comp_eq (c1 c2: comp): bool :=
match c1, c2 with
| nil_comp, nil_comp => true
| cons_comp a1 c1, cons_comp a2 c2 => all_eq a1 a2 && comp_eq c1 c2
| _, _ => false
end.
with comp_eq_lemma: forall l l0, if comp_eq l l0 then l = l0 else l <> l0.
Proof. (* you also lose guardedness:
exact all_eq_lemma.
exact comp_eq_lemma.
Qed. *)
generalize (comp_eq_lemma c c0).
destruct (comp_eq c c0).
Proof.
destruct l; destruct l0; simpl; try (intros; discriminate).
split.
generalize (all_eq_lemma a a0).
generalize (comp_eq_lemma l l0).
destruct (comp_eq l l0).
Qed.
One last thing, you may consider using Type insteal of Set.
It will be less efficient but more flexible.
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] A question about declaration and definition, geng chen
- Re: [Coq-Club] A question about declaration and definition, Damien Pous
- Re: [Coq-Club] A question about declaration and definition, Pierre Courtieu
- Re: [Coq-Club] A question about declaration and definition, AUGER
