- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction and recursive functions
- Date: Tue, 11 May 2010 18:15:06 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=V9EZ499CXGWQgB9QdFcyoy0HpuBR/EJzBhPvWC8ImWmARh/IT1Bn6/oiDzlkcB118b ge/xiLuEqeZTdxv0mlf4VDG12YdZM00RNCTbqjpr3EaTknDxxUvsLrxQaAWrJ21Pkgq4 4zMh/8ZwUN0JrI5LnJbOBZX/rz7P+2ZNkPgJ0=
Hello,
You may also want to use functional induction if the induction you
need folows the structure of f.
The usual way is to define f using Function and then:
Theorem mt : forall t u : term, App(f(t),f(u)) ->^* f(App(t,u))).
Proof.
intros t.
functional induction (f t).
You also have functional inversion to deduce things from hypothesis of
the form (f a) = t where t contains constructors.
Hope this helps.
Pierre Courtieu
Le 11 mai 2010 08:59, Stéphane Lescuyer
a écrit :
> Hi,
> You can introduce a new object equal to [f t] and perform the
> induction on this object instead. This is essentially a way of adding
> (before you start the induction) the dependency you were losing :
> Proof.
> intros.
> remember (f t) as h.
> induction h.
> (* now Heqh links [f t] to the destructed object *)
> You will then have to perform case analysis on [t] again if you want
> to deduce something about [t] itself, which means that your function
> should be somewhat inversible.
> Hope this helps,
> S.
> On Tue, May 11, 2010 at 4:49 AM, Flavio L. C. de Moura
>Â <flaviomoura AT unb.br>
> wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi Coq users,
>> I would like to prove a theorem about lambda-terms, for a given
>> recursive function f : term -> term. The theorem in Coq-like notation is:
>> The proof on paper is done by induction on f(t), but in Coq it didn't
>> work because I lose the relation between f(t) (in the left of the
>> reduction) and t (in the right of the reduction). For the var case, for
>> example, the function f is defined by f(x) = x; when I apply induction
>> (which is not the one that comes with Coq) I need to proof that
>> App(x,f(u)) ->^* f(App(t,u)) which is not true because the t on the
>> right of the reduction has nothing to do with the x on the left any
>> more. But, in fact, they are equal!
>> Maybe I need a stronger induction... or maybe I just don't know how to
>> do it in Coq...
>> Any help, or comments is very well welcome.
>> Best regards,
>> Flávio.
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v2.0.15 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAkvoxc4ACgkQJ9M3XSenoWhBTACg1wARXtYnw2AzVD/kglRmHHvV
>> hpwAoMw9hwXo+j+WHVKCUAZ251NP0DR2
>> =4BXw
>> -----END PGP SIGNATURE-----
> I'm the kind of guy that until it happens, I won't worry about it. -
> R.H. RoY05, MVP06
- [Coq-Club] Induction and recursive functions, Flavio L. C. de Moura
- Re: [Coq-Club] Induction and recursive functions,
Stéphane Lescuyer
- Re: [Coq-Club] Induction and recursive functions, Pierre Courtieu
Stéphane Lescuyer
