- From: Jacques Garrigue <garrigue AT math.nagoya-u.ac.jp>
- To: Roman Beslik <beroal AT ukr.net>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Hindley-Milner type inference algorithm
- Date: Wed, 19 May 2010 19:33:33 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:subject:mime-version:content-type:from:in-reply-to:date:cc :reply-to:content-transfer-encoding:message-id:references:to :x-mailer; b=k0T9juojmHsOTHe67z3VO1s9cmGB/6RF/BuMOykjUAor38WeUDfNBZ2FIUXiil+pty yOKnLoTgPrOrOixFtZGaBLhRDyarMptT+HYVYszeZ806LDiI5HrtBCbBgDShUlTspscj aSuybcR+WHkiS0SnzNeBpKp95JAWeuqvEDeQQ=
I see that you could find your file.
You can also have a look at my more recent scripts
A Certified Implementation of ML with Structural Polymorphism
http://www.math.nagoya-u.ac.jp/~garrigue/papers/
Unfortunately, they are for a much extended language, which means that they
are much more complex.
Jacques Garrigue
On 2010/05/19, at 17:16, Roman Beslik wrote:
> Thanks. Can I get Coq source code? The link provided in the paper is
> invalid.
> On 19.05.10 10:44,
>Â dubois AT ensiie.fr
> wrote:
>> Hi
>> Yes there is one done 10 years ago. Look at the following paper
>> C. DUBOIS, V. MÉNISSIER-MORAIN.Certification of a type inference tool for
>> ML: Damas-Milner within Coq. Journal of Automated Reasoning,Kluwer
>> Academic Publishers, vol 23, No 3-4, 319-346
>> Catherine Dubois
>> ------Message d'origine------
>> De : Roman Beslik
>> À : Coq-Club
>> Objet : [Coq-Club] Hindley-Milner type inference algorithm
>> Envoyé : 19 mai, 2010 09:01
>> Hi all. Is there a formalization of the subject in Coq?
> Best regards,
> Roman Beslik.
- [Coq-Club] Hindley-Milner type inference algorithm, Roman Beslik
- <Possible follow-ups>
- Re: [Coq-Club] Hindley-Milner type inference algorithm,
Roman Beslik
David MENTRE
- Re: [Coq-Club] Hindley-Milner type inference algorithm, David MENTRE
- Re: [Coq-Club] Hindley-Milner type inference algorithm, Jacques Garrigue
David MENTRE
- Re: [Coq-Club] Hindley-Milner type inference algorithm, Roman Beslik
