coq-club - Re: [Coq-Club] Cycle in dependent destruction (simplify_one_dep_elim)
chronological Thread
  • To: "Martijn Vermaat" <martijn AT vermaat.name>, coq-club <coq-club AT inria.fr>
  • Cc: "Dimitri Hendriks" <diem AT xs4all.nl>
  • Subject: Re: [Coq-Club] Cycle in dependent destruction (simplify_one_dep_elim)
  • Date: Wed, 26 May 2010 13:11:13 +0200
  • Organization: ProVal
Le Tue, 25 May 2010 13:52:08 +0200, Martijn Vermaat <martijn AT vermaat.name> a écrit:
Hello all,
I stumbled upon a strange (to me) problem with dependent destruction (or
dependent induction for that matter) where it gets stuck in a cycle.
I tracked down the problem to the repeated invocation of
simplify_one_dep_elim, which keeps generating the same simple equality.
The context is pretty involved, so I will try to simplify what happens
here and provide more details if they are asked for. For lack of
creativity, I will simply use _ wherever I leave out details.
We start with a hypothesis H on a inductive predicate E and a goal G:
  H : E _ _
   G
After 'generalize_eqs H' we get
  H : E _ _
   _ = _ -> _ = _ -> _ ~= _ -> G
where H is now simplified, as expected. Now 'destruct H' gives us three
cases, of which we are interested in the second one. The first
invocation of simplify_one_dep_elim adds two dependent pair equalities
to the goal, I will show the first:
(A)
   existT _ p (existT _ a x) = existT _ q (existT _ a y) ->
   ... -> G
All two subsequent simplify_one_dep_elim invocations will generate the
simple equality p = q and introduce it to the context, so we get
   p = q ->
   ... -> G
and then
(B)
  x : p = q
   ... -> G
and after another two invocations
  x0 : p = q
  x : p = q
   ... -> G
and so on, each time introducing the same equality as x1, x2, etc.
Now I know close to nothing about how this all works, but I'm guessing
that the problem is in the nested use of existT.
Can you explain what you expected to get?
At (B) step you have the same thing as in (A) (having just an equation more).
So it is normal, to have the same behaviour then.
We don't know much of your goal, so we can't really help.
Maybe that at step (B) you don't need the first equality of your goal anymore,
and should "intros _." to get rid of it, then perform a "case x." after reverting all hypotheses using "q"
(or a "subst." if you don't mind getting awful proof terms) and continue.
You should also tell the library you are using; according to Coq reference manual, "simplify_one_dep_elim"
is not a standard tactic (my Coq version >= 8.2 didn't recognized it at all).
If you need to prove also that "x = y" to continue, you will need more things
(by the way, don't mess with variables and hypotheses, you use "x" both as a hypothesis of type "p=q" and a parameter of "existT").
Of course you can't prove it as it doesn't type-check, take a look at JMeq, or this piece of code:
Coq < Lemma L1: forall A (P: A -> Type) x y z t, existT P x y = existT P z t -> exists H: P x = P z, (match H in (_=b) return b -> Prop with refl_equal => fun t => y = t end) t.
1 subgoal
   forall (A : Type) (P : A -> Type) (x : A) (y : P x) (z : A) (t : P z),
   exists H : P x = P z,
     match H in (_ = b) return (b -> Prop) with
     | refl_equal => fun t0 : P x => y = t0
     end t
L1 < intros.
1 subgoal
  A : Type
  P : A -> Type
  x : A
  y : P x
  z : A
  t : P z
  H : existT P x y = existT P z t
   exists H0 : P x = P z,
     match H0 in (_ = b) return (b -> Prop) with
     end t
L1 < inversion_clear H.
1 subgoal
  A : Type
  P : A -> Type
  x : A
  y : P x
  z : A
  t : P z
   exists H : P x = P (projT1 (existT (fun x0 : A => P x0) x y)),
     end (projT2 (existT (fun x0 : A => P x0) x y))
L1 < simpl.
1 subgoal
  A : Type
  P : A -> Type
  x : A
  y : P x
  z : A
  t : P z
   exists H : P x = P x,
     end y
L1 < exists (refl_equal _).
1 subgoal
  A : Type
  P : A -> Type
  x : A
  y : P x
  z : A
  t : P z
   y = y
L1 < split.
Proof completed.
L1 < Qed.
intros.
inversion_clear H.
simpl in |- *.
split.
L1 is defined
Is this something simplify_one_dep_elim cannot handle? Could I adjust
the tactic simplify_one_dep_elim_term in some way?
Or is this a sign there is something wrong with my development?
Thanks for any help,
Martijn
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
