- To: coq-club AT inria.fr
- Subject: Re: 回复: Re: [Coq-Club] usage of eq_ind
- Date: Fri, 28 May 2010 16:18:10 +0300
- Disposition-notification-to: Roman Beslik <beroal AT ukr.net>
Hi. "x=y" (as type) is a set of proofs of the proposition "x=y", IMHO.
Implication (as type constructor) constructs a set of functions that
transform a proof into another proof in some way. On 28.05.10 13:59, 许庆国 wrote: What's meaning of the type "x=y" ? Is it a predication type over type A,or a Set type or the dependent product type?-- Best regards, Roman Beslik. |
- [Coq-Club] usage of eq_ind, qgxu
- Re: [Coq-Club] usage of eq_ind, Adam Chlipala
- Re: [Coq-Club] usage of eq_ind, Pierre Casteran
- ظ: Re: [Coq-Club] usage of eq_ind,
- Re: ظ: Re: [Coq-Club] usage of eq_ind, Pierre Casteran
- Re: 回复: Re: [Coq-Club] usage of eq_ind, Roman Beslik
