- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Another question about rewriting
- Date: Sun, 20 Jun 2010 12:35:35 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=r5CZwomzrtNgRZJPn+m58nFkaWnhSQG5XbFtUxO4vTQ6ZIxEtecIKl19ePeHVDdsBW xuKtpuCU3tQi/VLW7pXiw48+qk4aCDj+61JhJOBMR/FzK2wh1ciZQgUJUKyIPiv0iHfI CEZD9AW1zCBeFbPpWJw3nlZy3k4u84drJyXbc=
Dear all,
I have another question about rewriting, about unsatisfiable
constraints this time. A little bit of context: the lemma I'm
currently working on involves a proof about structural equivalence
[struct] between pi-calculus terms. [struct] is a symmetric and
transitive parametric relation, but is not reflexive because it is
defined only over locally closed terms. I have a proof obligation of
the form
struct (par P Q) (par (out sub obj Q') (par Q Q''))
and a hypothesis
IH1 : struct P (par (out sub obj Q') Q'')
I want to rewrite the goal with IH1. This should work since [par] has
been declared as a morphism struct ==> struct ==> struct.
Unfortunately,
rewrite IH1
give the following error:
?356228 == (Morphisms.MorphismProxy ?356226
(par (out sub obj Q') (par Q Q'')))
?356227 == (Morphisms.Morphism
(?356222 ==> ?356226 ==> Basics.flip Basics.impl) struct)
?356226 == (relation proc)
?356225 == (Morphisms.MorphismProxy ?356223 Q)
?356224 == (Morphisms.Morphism (struct ==> ?356223 ==> ?356222) par)
?356223 == (relation proc)
?356222 == (relation proc).
I think the problematic constraint is the constraint
about the part that remains the same during the rewrite. When I
instantiate ?356223 with Q manually:
assert (Morphisms.MorphismProxy struct Q) by
(compute ; auto).
the rewrite goes through. Alternatively, I also have an identity
relation [lc_eq] restricted to locally closed terms (and have proven
that [par] is also a morphism struct ==> lc_eq ==> struct), and when I
replace the above assert by
assert (Morphisms.MorphismProxy lc_eq Q) by
(compute ; auto).
the proof goes through too. In both cases, the proof goes through
because there is a hypothesis in the context that Q is locally closed.
Without the assert, however, the rewrite gets stuck. What I *suspect*
happens is that the constraint solver picks 'eq' for the constraint
which makes the constraint
unsolvable (because the proof of that goal will now involve reasoning
about terms that are not locally closed).
Might that suspicion be correct, and if so, what can I do about it?
Thanks,
Edsko
- [Coq-Club] Another question about rewriting, Edsko de Vries
