- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Module, opacity and reflexion
- Date: Wed, 7 Jul 2010 09:00:29 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:cc:content-type :content-transfer-encoding; b=pHjccNZMz5LMb3ep+LcB+L65Fjvt+Df5j4Ju4T6MSVAgC4PxQNIxI5CUkGJrZO6EfK FLbYsAJqZmaPmEZaTiFbRp6WaZHpGNk3XZ3MvYCQFXg3viEwb8XRv/p+a4iHzpy97kUl GxdEM/lLkb1Kd4QUnFm5ogfApYEB2KZExSnsE=
We have got exactly the same problem in our ATBR library...
We found no solution yet, except using functors everywhere, which is
impractical.
Damien (and think Thomas would agree...)
Le 7 juillet 2010 08:51, Pierre-Marie Pédrot
<pierremarie.pedrot AT ens-lyon.fr>
a écrit :
> Dear Coq users,
> I am currently facing a quite serious problem by trying to mix modules
> with reflexive tactics.
> Actually, I would like to use modules in order to:
> 1. Have a nice abstract layer for proof and hide the implementation in
> further proofs;
> 2. Prevent cluttering of the namespace with irrelevant intermediary lemmas.
> That means, I do use declarations
> Module X : T := ...
> and NOT
> Module X <: T := ....
> Yet at the same time, I would like to be able to build up reflexive
> tactics operating on the contents of the module. Alas, it does not work
> precisely because of the opaque nature of the content of the module
> (which is something I want...). I have tested a lot of combinations, and
> they are all more or less flawed.
> 1. What does not work:
> Defining reflexive tactics in the module body: they are not exported.
> Defining reflexive tactics in the module type, instead of in the module
> body; terms are still opaque, so it does not reduce. (Maybe one day when
> we have abstract tactics in module types?)
> 2. What does partly work:
> Do not use either abstraction of reflexivity: relatively useless...
> Mix computational reflexivity with ltac rewriting: hell on earth (slow,
> unsecure, unmaintainable).
> And the best I came with, which is in my opinion an UGLY hack, by doing
> as follows:
> Module X <: T :=
> (* definitions *) ...
> (* HACK-a-tron *)
> Global Opaque ... all_transparent_defs ...
> End X.
> Module Tactics. Import X.
> Transparent ... relevant_defs ...
> (* tactics *) ...
> End Tactics.
> This is not totally satisfactory because while partially abstracting
> definitions, we still have a cluttered namespace.
> 3. What should work:
> Have a semi-transparent flag stating that this term is transparent for
> reduction but not for unfolding in proofs (I don't think this is possible).
> Have a way to define in-module abstract tactics that can work on the
> transparent term while hiding the inner parts of the module.
> So did you encounter this problem, and did you find a partial workaround
> (I assume there is no way to do so)? Actually, the more I use the module
> system, the more I find it useless because while providing a VITAL way
> to abstract things, it does conflict with a lot of other parts of Coq.
> PMP
- [Coq-Club] Module, opacity and reflexion, Pierre-Marie Pédrot
- Re: [Coq-Club] Module, opacity and reflexion, Damien Pous
- Re: [Coq-Club] Module, opacity and reflexion, Stéphane Glondu
