- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: Sylvain Dailler <sylvain.dailler AT ens-lyon.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem : compatibility of inversion and Prop
- Date: Tue, 13 Jul 2010 11:45:47 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:cc:subject:message-id:references:mime-version :content-type:content-disposition:in-reply-to:user-agent; b=BfWrW+MbyO/+eErFvF3GCHMkJs8IOzBFJzMDVRbXcoTmHrR9xkPRl8cSMwYXDkI3j2 P5IPpyv/AwWFMI43EV7S9n7dmrRG1GGhFzAUVNye/+G6hCyJLRsTRL7ys11LJMnhnUpy 566HGZEjAr2gDm03Bd7E8uokwMs5C3QCN/W/k=
Hello,
Try using case instead of inversion.
Here there is no link between Hpipo and the conclusion,
hence you have to invent one, e.g. using refl_equal.
example_context <
1 subgoal
x : A
Hpipo : example x A0
False
generalize (refl_equal A0); generalize (refl_equal x).
pattern x at -1, A0 at -1.
case Hpipo; intros x0 y eqx eqA.
For more information, the material I just presented at the
2nd Coq Workshop, may be useful, see my webpage.
Hope this helps,
JF
On Tue, Jul 13, 2010 at 11:16:36AM +0100, Sylvain Dailler wrote:
> Dear Coq users,
> I would like to use the inversion tactic in the sort Prop. But this
> tactic
> has not the same behavior as in Set. I don't understand why.
> My problem can be summarized with this little example :
> Variable A : Set.
> Variable plus : A -> A -> A.
> Infix "+" := plus.
> Variable A0 : A.
> Variable A1 : A.
> Inductive example : A -> A -> Prop :=
> | example0 : forall x y, example x (y + A1).
> Lemma example_context : forall x, example x A0 -> False.
> Proof.
> intros x Hpipo.
> inversion Hpipo.
> (*now look at the context with A : Prop*)
> Admitted.
> Now, if I change "Variable A : Set." into "Variable A : Prop.", the
> context generated by the inversion tactic is not the same. This
> hypothesis
> disappeared :
> "H1 : y + A1 = A0"
> I would like to know why contexts are different. I don't think I am doing
> anything wrong with the Prop sort.
> Do you know where I can find the code of the inversion tactic ?
Jean-Francois Monin
CNRS-LIAMA, Project FORMES & Universite de Grenoble 1
Office 3-605, FIT, Tsinghua University
Haidian District, Beijing 100084, CHINA
Tel: +86 10 62 79 69 79 ext 605
Fax@LIAMA:
+86 10 6264 7458
- [Coq-Club] Problem : compatibility of inversion and Prop, Sylvain Dailler
- Re: [Coq-Club] Problem : compatibility of inversion and Prop, Jean-Francois Monin
- Re: [Coq-Club] Problem : compatibility of inversion and Prop, Sylvain Dailler
