coq-club - Re: [Coq-Club] is matching bool slower than sum?
chronological Thread
  • To: Jianzhou Zhao <jianzhou AT seas.upenn.edu>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] is matching bool slower than sum?
  • Date: Mon, 19 Jul 2010 11:22:45 -0700
Hello,
InInsns_dec is declared opaque (Qed) - maybe this is stopping reduction much earlier than with your other boolean functions?
-Ryan
On 7/18/2010 9:57 AM, Jianzhou Zhao wrote:
Hi,
For some reason I have a definition 'insnEq' that compares two 'insn's
and returns bool. The 'insn' defines instructions in a language.  What
'insnEq' does is just matching the two instructions and checking if
their sub-components are equal with corresponding 'comparison'
functions (which are defined in the similar fashion). Then I defined
others 'Fixpoint's :
Fixpoint InInsns (i:insn) (li:list insn) {struct li} : bool :=
match li with
| nil =>  false
| i' :: li' =>  insnEq i i' || InInsns i li'
end.
Definition block := list insn.
Fixpoint foo(i:insn) (lb:list block) {struct lb} : option block :=
match lb with
| nil =>  None
| b::lb' =>
   match (InInsns i b) with
   | true =>  Some b
   | false =>  foo i lb'
   end
end.
The compilation of foo is very slow, it takes around 2-3 mins. But, if
I proved this decidability lemma first,
Lemma InInsns_dec : forall i b,
   {InInsns i b = true} + {InInsns  i b = false}.
Proof.
   intros. destruct (InInsns i b); auto.
Qed.
and then let foo match InInsns_dec,
Fixpoint foo2(i:insn) (lb:list block)) {struct lb} : option block :=
match lb with
| nil =>  None
| b::lb' =>
   match (InInsns_dec i b) with
   | left =>  Some b
   | right =>  foo2 i lb'
   end
end.
Coq compiles this foo2 immediately. Why is the first 'foo' slow?
Thanks.
