- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Parameterized Instances for type classes
- Date: Tue, 20 Jul 2010 14:58:23 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:from:date:x-google-sender-auth:message-id :subject:to:content-type; b=WogqeruZSZRsve9lQhJWjx3THcr8v6Ma2UuNskhmFIvUHb2OVIWQY5/CcFnSP354hV 1JuCIlnhCu8UJgWEsX22neIXt94uHT5C7oWGIMICfo1leLOQ4SAOTSdBnVZtVcNhsRsV ZeMCbRuXUAqLcjT+AO5/yDjAw+neOB8mcXmHE=
Dear list!
I'm currently playing with type classes in Coq. My goal is to write
some "do notations", but I will present a smaller example (see the
attached file)
I have a class Pointed
Class Pointed (M:Type -> Type) := {
creturn: forall {A: Type}, A -> M A
with a creturn function (just "return" is sadly not valid).
I often have function that returns a "pair", with the first element of
the pair being the interesting result of the function, and with a
second element that could most of the time be calculated
"automatically" (what I really want here is a monad with bind a
return, but for the simplicity of my question, I'll just present
return).
But I don't want to define a new Instance for each second type (and
sometimes I want a different default element). That's why I defined a
special pair type, with the default element in it:
Unset Implicit Arguments.
Inductive FPair (A B:Type) (neutral: B) : Type:=
fpair : forall (a:A) (b:B), FPair A B neutral.
Implicit Arguments fpair [[A] [B] [neutral]].
Set Implicit Arguments.
Notation "( x ,> y )" := (fpair x y) (at level 0).
This type is easily Pointed (with a Parameterized instance):
Instance Pointed_FPair B neutral:
Pointed (fun A => FPair A B neutral) :=
{ creturn := fun A (a:A) => (a,> neutral) }.
But when I try to use it:
Definition blah_fail (x:bool) : FPair bool nat O :=
creturn x.
the instance search fails:
Toplevel input, characters 75-82:
Error: Cannot infer the implicit parameter Pointed of
creturn.
Could not find an instance for "Pointed ?33" in environment:
x : bool
With the following constraints:
?34 == (Pointed ?33)
?33 == (Type -> Type)
If I help by giving the instance, it works:
Definition blah_explicit (x:bool) : FPair bool nat O :=
@creturn _ (Pointed_FPair _ ) _ x.
or when I give a simple instance:
Instance Pointed_FPair_mono:
Pointed (fun A => FPair A nat 0) :=
{ creturn := fun A (a:A) => (a,> 0) }.
Definition blah (x:bool) : FPair bool nat O :=
creturn x.
Did I do anything wrong with the implicit arguments? Is it possible to
make the "natural" version work?
Thanks!
TestClass.v
Description: Binary data
- [Coq-Club] Parameterized Instances for type classes, Alexandre Pilkiewicz
- Re: [Coq-Club] Parameterized Instances for type classes,
Matthieu Sozeau
- Re: [Coq-Club] Parameterized Instances for type classes, Alexandre Pilkiewicz
Matthieu Sozeau
