coq-club - Re: [Coq-Club] Powerset construction for FSets
chronological Thread
  • From: Thomas Braibant <thomas.braibant AT gmail.com>
  • To: David Pereira <dpereira AT liacc.up.pt>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Powerset construction for FSets
  • Date: Fri, 23 Jul 2010 12:05:38 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type:content-transfer-encoding; b=H7CKrnjJTWrUw2GPsiWAydC8UPxUEqjZp/mIHO8aqfvlp72T5gyyqs15lmriXYIee3 jaCaxmC1hhG76PVuIaAwrMT9i+PRCJ1uzrr7LfOpNSHmVlF0KxKXKznT05ethLjn014Y RNjfo19bVX4PwCVRNu2Rtaub0rhPonkm366aY=
Hi,
If you are interested in the powerset construction for finite sets as
in 'the powerset construction' or 'subset construction' that converts
NFA to DFA, you might have a look to our ATBR library [1] that
features a decision procedure for Kleene algebras implemented through
construction, determinisation and equivalence checking of finite
automata in Coq, using a lot of FSets and FMaps. In particular, we
have a module that determinise epsilon-free finite autmata.
Alternatively, if you wish to implement the powerset construction that
builds the 2^n subsets of a given set of size n,  here is a piece of
code that should do the job [2]...
thomas
[1] http://sardes.inrialpes.fr/~braibant/atbr
[2]
Require Import FSets FSetInterface.
Require Import Program.Wf.
Module subset ( M : FSetInterface.S).
  Module MSet := FSetList.Make (M). (* or FSetAVL , to represent sets of sets
  Definition add x (m : MSet.t) : MSet.t :=
    MSet.fold (fun s acc => MSet.add (M.add x s) acc ) m MSet.empty.
  Program Fixpoint subset (s : M.t) {measure (M.cardinal s)}: MSet.t :=
    match M.choose s with
      | None => MSet.empty
      | Some x => let s := subset (M.remove x s) in
        MSet.union (add x s) s
    end.
  Next Obligation. Admitted. (* the size is decreasing *)
End subset.
On Wed, Jul 21, 2010 at 7:35 PM, David Pereira
 wrote:
> Hi all,
> Does anyone know about any implementation of the powerset construction for
> finite sets that is compatible with the FSet library of Coq's standard
> library?
> Thanks in advance.
> Best regards,
>  David.
