coq-club - Re: [Coq-Club] [change]: "not convertible"
chronological Thread
  • From: Vincent Siles <vsiles AT lix.polytechnique.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] [change]: "not convertible"
  • Date: Mon, 26 Jul 2010 15:00:02 +0200
On 26/07/2010 14:54, Michael wrote:
Hello,
I'm trying to proof an inequality like the following:
Lemma lem1:
forall (x:Z),
(x * 64 / 8 + 1)>= x * 8.
I tried to start changing the term:
change ((x * 8 + 1)>= x * 8).
but I receive the error message "Error: not convertible". It seems to have
something to do with the brackets. If the statement is (x * (64 / 8) ...), I
can easily change the term, and prove it.
My first thought was, it might be because of x being of type Z, so in general,
x * y / z<>  x * (y / z), if x * y is not a multiple of z. I then tried
another
Lemma:
Lemma lem2:
forall (x:Z),
x - 5 + 3 = x - 2.
In this simple example, I could of couse prove it with intuition in a single
step. But even here, "change (x - 2 = x - 2)" fails already.
Why can't I change the terms in those 2 cases?
In general, what is the best approach to simplify more complex inequalities of
such type?
Change can only exchange term which are ``convertible'' according to
Coq's conversion. If you need to prove that those term are equal, you will
have to use replace instead of change.
And I think you have the syntax wrong: to change A by B, you have to enter
change A with B.  (replace uses the same syntax).
Here is a simple example:
  x : nat
   1 + x = S x
Unnamed_thm < change (1+x) with (S x).
1 subgoal
  x : nat
   S x = S x
1 + x will compute to S x since plus pattern matches on the first argument.
Both terms are \beta equal.
  x : nat
   x + 1 = S x
Unnamed_thm < change (x+1) with (S x).
Toplevel input, characters 0-23:
Error: Not convertible.
This time, you need to *prove* that x+1 is the same thing at S x (by induction on x or whatever),
this is not direct by computation.
Hope it helps,
Vincent
Sincerely,
Michael
