- From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- To: Jean-Marie Madiot <madiot AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Partial modification of records
- Date: Thu, 29 Jul 2010 01:07:54 -0700
Hello,
I don't know of any builtin ways to do this, but you can do it with a little bit of reflection. I can't seem to find my latest version, but something like the code that is located here will give you the ocaml-style with notation. Proving things about them is a little painful, but they compute nicely. I'll look for my other version which has better proof support if you're interested.
Hope this helps.
gregory malecha
On Wed, Jul 28, 2010 at 7:44 AM, Jean-Marie Madiot <madiot AT gmail.com> wrote:
Hello all,
I'm currently using the Record syntactic sugar and I was wondering if
it is possible to build a record instance from an existing one while
modifying only a few fields. To be clear, I have a record with many
fields, like this:
Record rec := rec_cons {
rec1 : nat;
rec2 : nat;
rec3 : nat;
recdots : nat
(* and I built an instance of rec: *)
Definition r : rec := rec_cons 1 2 3 4.
Definition r2 : rec := {| rec1 := 1; rec2 := 2; rec3 := 3; recdots
:= 4 |}. (* same thing *)
(* now I want to make an instance based on r but modifying only one
field, like that: *)
Definition r' : rec := {| r with rec2 := 20 |}.
But it does not work like that. (This is inspired from the ocaml
syntax). Is there another way? I know I can do such a thing by
defining my own function depending on my record type and which field I
want to alter -- and even setting up a notation for it -- but since
records are already just syntactic sugar, maybe it is possible to have
something more general?
Or maybe it interferes with the existing notation system?
Regards,
Jean-Marie
gregory malecha
- [Coq-Club] Partial modification of records, Jean-Marie Madiot
- Re: [Coq-Club] Partial modification of records, Gregory Malecha
