- To: Evgeny Makarov <emakarov AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Extracting integers from Coq to OCaml
- Date: Mon, 16 Aug 2010 22:19:14 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=OqVU9DRqKUZCzyOTVYxJRpeC6tYxBp/ARXo3IinIwNW1xaGJVS2sMOTjEFqea4+235 MgZj4E37uUjx11wS9ttz3cSK7/TAJivYxz0L3aa32wQcPCoz6c+x5QFc8bnJV1ALHvqF 0jOMkND3gexiky56HFmC4Sf8PWTV4iax8qpRI=
On Mon, Aug 16, 2010 at 6:06 PM, Jianzhou Zhao
<jianzhou AT seas.upenn.edu>
wrote:
> On Mon, Aug 16, 2010 at 4:23 PM, Evgeny Makarov
>Â <emakarov AT gmail.com>
> wrote:
>> Jianzhou,
>>> I think Coq extraction
>>> (http://coq.inria.fr/refman/Reference-Manual027.html#toc139) only
>>> allows to realize inductive Coq types into inductive OCaml types. But
>>> OCaml's int or big_bit is only primitive.
>> The Reference Manual section 21.2.4 (at least after trunk 13264) has
>> an example of extracting the inductive Coq type nat to OCaml type int.
>> The command is "Extract Inductive". You can also probably use "Extract
>> Constant" to map functions on a Coq type into built-in OCaml
>> functions.
> Thanks. This works.
> Extract Inductive nat => "int" [ "0" "succ" ].
> Extract Constant plus => "fun a b -> a + b ".
> Definition _plus (a b:nat) := plus a b.
> Extraction "test" _plus.
> I had assumed that "Extract Constant" only works for Axioms. The
> reference also gives such syntax to extract constant:
> Coq < Extract Constant plus "’a" "’b" => " ’a*’b"
> What is the symbol before a and b, I tried ' and `, it extracted
> let rec plus -> ’a*’b
> I might use a wrong symbol.
> If the extracted type, say 'big_int', is not in a module opened by
> default, can we also specify OCaml dependencies, adding 'open Big_int'
> before extracted code?
This is not a question. It can extract to "Big_int.big_int" directly.
>> Evgeny
> Jianzhou
Jianzhou
- [Coq-Club] Extracting integers from Coq to OCaml, Jianzhou Zhao
- Re: [Coq-Club] Extracting integers from Coq to OCaml,
Evgeny Makarov
Jianzhou Zhao
- Re: [Coq-Club] Extracting integers from Coq to OCaml, Jianzhou Zhao
Pierre Letouzey
Jianzhou Zhao
Evgeny Makarov
