- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Cannot match on the parameter of an inductive
- Date: Fri, 20 Aug 2010 14:55:23 +0200
Hi,
On 08/20/2010 12:34 PM, Evgeny Makarov wrote:
I don't have the solution, but this does look strange. If there are
two snippets of code of which only one works and which differ only in
"match e with" and "match id e with", then it looks like Coq does not
have the subject reduction property...
Coq does fail to enjoy the subject reduction property, but not for that reason. (Search in this mailing list archive about coinductive types...)
On 08/18/2010 06:04 PM, Alexandre Pilkiewicz wrote:
> Variables A B: Type.
> Variable PA: A -> Prop.
> Variable PB : B -> Prop.
> Inductive either : Type :=
> | EA (a: A)
> | EB (b: B).
> Inductive P (e: either) : Prop :=
> |P_intro:
> match e with
> | EA a => PA a
> | EB b => PB b
> end -> P e.
> leads to : Error: A parameter or name of an inductive type e must not
> be used as a bound variable in the type of its constructor.
Expressions like match e with ... end
are not pure CIC expressions: they need elaboration, for instance to determine the "elimination predicate" (the P variable in the either_rect constant) or the return clause of the match.
When you do a match on a variable (as opposed to (id e)), it is understood as match e as e return Q(e) with ... end
where Q(e) is the return type, abstracted over e to express the dependency, and the system does its best to guess Q.
As you see, the interface is adding for you a binder with name e. In general this is a bad thing when a binder shadows a parameter in a constructor type, because this might prevent you from writing any instance of your inductive type under that binder (inductive P must be applied to parameter e, but e is now bound to something else).
This is too defensive here since we don't need to invoke P, and in fact positivity prevents you from using P in that position! So the error should at most be a warning, but since the binder is not introduced by the user, it should be accepted silently.
> But if I write :
> Inductive P : either -> Prop :=
> |P_intro: forall e,
> match e with
> | EA a => PA a
> | EB b => PB b
> end -> P e.
Accepted because you don't hide a parameter.
> or more strangely
> |P_intro:
> match id e with
> | EA a => PA a
> | EB b => PB b
> end -> P e.
Accepted because the system does not create a binder with name e.
> Is there a reason for such a limitation ?
No good reason, besides the explanation above.
You could report this to coq-bugs so that it eventually gets fixed. Meanwhile, you can force Coq to choose another name for the binder:
match e as e' with ... end
Hope this helps,
Bruno Barras.
- [Coq-Club] Cannot match on the parameter of an inductive, Alexandre Pilkiewicz
- Re: [Coq-Club] Cannot match on the parameter of an inductive,
Evgeny Makarov
- Re: [Coq-Club] Cannot match on the parameter of an inductive, Bruno Barras
Evgeny Makarov
