- To: coq-club AT inria.fr
- Subject: [Coq-Club] Depenednt types and equality proofs
- Date: Thu, 2 Sep 2010 20:17:24 +0100
Hi all,
I am trying to write a proof that inverting something twice is the
identity. I have a proof (thingInverseInverseDestructingSign in the
attached script), but it involves destructing Sign, which feels
unsatisfactory to me.
I would prefer a way to prove it that doesn't depend on the
implementation of Sign. The problem is that the two things I am trying
to prove the equality of are of this type:
Record Thing (from to : natSet) : Type := mkThing {
th_me : SignedNat;
th_natOK : natOK from to th_me
so if the th_me's have a different value, then f_equal does nothing as
the types of the th_natOK's are different.
"apply proof_irrelevance." believes that it can prove it, but Qed
disagrees (probably another instance of bug #2240) (thingInverseInverse
in the attached script).
Is there a way to complete this proof without destructing the Sign?
Thanks
Ian
Require Export FSets.
Require Export FSetDecide.
Require Export FSetProperties.
Require Import FSetWeakList.
Require Import Peano_dec.
Require Import ProofIrrelevance.
(* BEGIN: make a "Set of nat" type *)
Module DecidableNat.
Definition t := nat.
Definition eq := @eq nat.
Definition eq_refl := @refl_equal nat.
Definition eq_sym := @sym_eq nat.
Definition eq_trans := @trans_eq nat.
Definition eq_dec := eq_nat_dec.
End DecidableNat.
Module natSetMod := Make(DecidableNat).
Notation natSet := (natSetMod.t).
Notation natSetIn := (natSetMod.In).
Notation natSetAdd := (natSetMod.add).
Notation natSetEqual := (natSetMod.Equal).
(* END: make a "Set of nat" type *)
Inductive Sign : Set
:= Positive | Negative.
Inductive SignedNat : Set
:= MkSignedNat : forall (s : Sign)
(n : nat),
SignedNat.
Definition signedNatInverse (n : SignedNat) : SignedNat
:= match n with
| MkSignedNat Positive b => MkSignedNat Negative b
| MkSignedNat Negative b => MkSignedNat Positive b
end.
Lemma signedNatInverseInverse : forall (sn : SignedNat), signedNatInverse
(signedNatInverse sn) = sn.
Proof with auto.
intros.
destruct sn.
destruct s...
Qed.
Definition natOK (from to : natSet)
(sn : SignedNat)
: Prop
:= match sn with
| MkSignedNat Positive n => (~ natSetIn n from)
/\ (natSetEqual to (natSetAdd n from))
| MkSignedNat Negative n => (~ natSetIn n to)
/\ (natSetEqual from (natSetAdd n to))
end.
th_me : SignedNat;
Implicit Arguments mkThing [from to].
Implicit Arguments th_me [from to].
Implicit Arguments th_natOK [from to].
Lemma natOKInverse : forall {from to : natSet}
{n : SignedNat}
(ok : natOK from to n),
natOK to from (signedNatInverse n).
Proof with auto.
intros.
destruct n.
destruct s.
simpl.
destruct ok.
split...
simpl.
destruct ok.
split...
Qed.
Definition thingInverse {from to : natSet}
(thing : Thing from to)
: Thing to from
:= mkThing (signedNatInverse (th_me thing))
(natOKInverse (th_natOK thing)).
Lemma thingInverseInverseDestructingSign :
(p : Thing from to),
thingInverse (thingInverse p) = p.
Proof with auto.
intros.
destruct p.
unfold thingInverse.
simpl.
destruct th_me0.
destruct s.
simpl.
f_equal.
simpl.
f_equal.
Qed.
Lemma thingInverseInverse :
Proof with auto.
intros.
destruct p.
simpl.
(* Now want to be able to say: *)
f_equal.
(* but it does nothing, as the types don't match *)
(* We /are/ able to apply proof irrelevance: *)
(* But then Qed fails with a type error: *)
Qed.
- [Coq-Club] Depenednt types and equality proofs, Ian Lynagh
