- From: Florent Becker <florent.becker AT ens-lyon.org>
- To: coq-club AT inria.fr
- Cc: Gyesik Lee <gslee AT ropas.snu.ac.kr>
- Subject: [Coq-Club] Re: match goal with "match ... with"
- Date: Thu, 16 Sep 2010 14:34:25 +0200
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Le 02/07/2010 15:08, Adam Chlipala a écrit :
> Gyesik Lee wrote:
>> Then I tried with
>> Ltac toto :=
>> match goal with
>> | |- context [ match ?T with | _ => _ end ] => idtac
>> end
>> The error message now:
>> Error: Non supported pattern.
> For now, you need to supply every pattern-match case, in enough detail
> to make clear which type you're matching on. It gets bothersomely
> verbose and prevents genericity, but it makes some sense if you look at
> the internal representation of Gallina terms.
I have run into the same problem while trying to define the following
tactic:
Ltac case_at_head :=
match goal with
| |- [ match ?T with | _ => _ end ] => case_eq T
end
Does an equivalent tactic exist somewhere? I'd like to be able to solve
goals like this:
f : nat -> option nat
n : nat
H1 : forall k, a k
H2 : b
match f n with
| Some k => a k
| None => b
end
without having to mention (f n), so that i can solve them automatically
(by 'case_at_head; auto')
As far as I can tell, I'd need to implement that tactic as an ocaml
plugin, but I've not been able to find documentation on how to do that.
Thanks for any pointers,
Florent
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkySDtEACgkQTCPcDztjGo7ffACeOx/QL9XLBrLKrsjWa/608HV4
BKgAoJF+k7kQa/QN0TnhadIqLCtRrdU1
=KNiH
-----END PGP SIGNATURE-----
- [Coq-Club] Re: match goal with "match ... with", Florent Becker
- [Coq-Club] Re: match goal with "match ... with", Gyesik Lee
