- To: coq-club AT inria.fr
- Subject: [Coq-Club] an inductive definition?
- Date: Sat, 18 Sep 2010 14:04:12 -0400
I wonder if the following "mutually inductive" definition is possible in any
of the languages/proof assistants (e.g. Agda):
Inductive U (T:Type) :Type := gen: U | prod: forall X:U, forall P: elem X ->
Type, U
with
fixpoint elem (X:U) : Type :=
match X with
| gen => T
| prod Y P => forall y: elem Y, P y
end.
The intuition behind it is to define the universe U generated by a type T
with respect to dependent products together with the function elem: U -> T
which sends X:U to its underlying "type of elements".
The basic problem here is that a type is inductively defined simultaneously
with a fix-point function on it.
Vladimir.
- [Coq-Club] Machine checked proof of replacement lemma, Sunil Kothari
- [Coq-Club] an inductive definition?, Vladimir Voevodsky
- Re: [Coq-Club] an inductive definition?, Guilhem Moulin
- [Coq-Club] an inductive definition? (correction), Vladimir Voevodsky
