- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] change in behavior from 8.2pl3 to 8.3rc1 -- bug?
- Date: Mon, 20 Sep 2010 14:46:41 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:content-type:mime-version:subject:from:in-reply-to:date :content-transfer-encoding:message-id:references:to:x-mailer; b=E3DpXunFcjxIpmB7jeRWTgiSuZLrqn/sfpXTWrmD8eHSys2qidhWr0DZDOX8MqtiU5 IMF0Tnx8sAZ3ofXLj76mfeNYdh7PV1pJaTJSU/GJpp423WscIg5xRAb5nHMYE0FTQ4dE VSLTbo6MmZDJlK0p2CcSUu+DpS3s7kYlcl05c=
Hi Adam,
yes, there is an incompatible change in 8.3: you have
to declare that [A] is generalizable using the
[Generalizable Variables A.] vernacular command (documented
in the reference manual).
-- Matthieu
Le 20 sept. 2010 à 14:28, Adam Megacz a écrit :
> (* The script below works with 8.2pl3 but reports "Error: Unbound and
> * ungeneralizable variable A" with 8.3rc1 *)
> Inductive list (A:Type) : Type :=
> | nil : list A
> | cons : A -> list A -> list A.
> Implicit Arguments nil [A].
> Implicit Arguments cons [A].
> Infix "::" := cons (at level 60, right associativity).
> Lemma list_cannot_be_longer_than_itself : forall `(a:A)(b:list A), b =
> (a::b) -> False.
> intros.
> induction b.
> inversion H.
> inversion H. apply IHb in H2.
> auto.
> Defined.
- [Coq-Club] change in behavior from 8.2pl3 to 8.3rc1 -- bug?, Adam Megacz
- Re: [Coq-Club] change in behavior from 8.2pl3 to 8.3rc1 -- bug?, Vilhelm Sjöberg
- Re: [Coq-Club] change in behavior from 8.2pl3 to 8.3rc1 -- bug?, Matthieu Sozeau
