- To: coq-club AT inria.fr
- Subject: [Coq-Club] apply to all subgoals?
- Date: Mon, 20 Sep 2010 19:02:32 +0000
- Cancel-lock: sha1:OUyO/ueOU5nPSMzS3cFH12sSMWk=
- Organization: Myself
The "<num>:<tactic>" syntax makes it possible to apply a tactic to a
specific subgoal; for example:
3:simpl.
Is there a version of this which applies a tactic to all subgoals? I
tried the obvious
*:simpl.
But that's not valid syntax.
The case where this matters most (to me, at least) is when an [Instance]
declaration using the { ; ; } syntax generates a large number of
subgoals which can all be discharged with the same tactic; for example
Instance foo : bar :=
{ baz := blah
(* many obligations remain here *)
In the past I've rewritten this sort of thing as
Instance foo : bar.
apply Build_bar with (baz:=blah)
; magical_tactic.
Defined.
But that's probably not the ideal way to go about this and is a bit less
pleasant for people reading the proof.
I suppose I could also use [Program Instance] and [Solve All Obligations
using]; I'm just wondering if there's another solution.
Thanks,
- a
- [Coq-Club] apply to all subgoals?, Adam Megacz
- Re: [Coq-Club] apply to all subgoals?,
Alexandre Pilkiewicz
- [Coq-Club] Re: apply to all subgoals?, Adam Megacz
