coq-club - Re: Re: [Coq-Club] Problem with Gappa installation
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: Re: [Coq-Club] Problem with Gappa installation
  • Date: Sun, 26 Sep 2010 12:51:14 +0200
Gappa installation now worked with libcoq-ocaml-dev installed.
Since I got the coq proof obligations from frama-c jessie plugin via C code,
with the new floating point operations I now have a couple of references coq
doesn't find.
The reference "double_value x" wasn't found at first, I could solve this
problem by manually downloading the floating point library from the coq
website, compliling *.v and copying it to /usr/lib/coq/user-contrib/. Then I
could "Require Export Float." (which wasn't possible before).
However, there's still a couple of references coq doesn't find
(no_overflow_double, nearest_even, double_of_real_post, truncate_real_to_int).
How can I find out which modules I have to load, and where to find them?
Sincerely,
