- To: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] rewrite problem
- Date: Thu, 30 Sep 2010 18:35:04 -0400
M. Scott Doerrie wrote:
Why won't "rewrite Hopt2 in Hopt6" work. It fails with: Found no subterm matching "Sem.S.RefMapS.find a s" in Hopt6. It's clearly present, even when using "Set Printing All."
Assuming that you've eyeballed the code properly and checked that the terms really match (which I haven't done), the problem could be that [Hopt6] would no longer be well-typed after the rewrite. I suggest running [Check P], where [P] is a hand-rewritten version of the term. If this fails, then you'll have the culprit. The [rewrite] error message for cases like this could definitely be improved. ;)
- [Coq-Club] rewrite problem, M. Scott Doerrie
- Re: [Coq-Club] rewrite problem, Adam Chlipala
M. Scott Doerrie
Alexandre Pilkiewicz
M. Scott Doerrie
- Re: [Coq-Club] rewrite problem, Alexandre Pilkiewicz
M. Scott Doerrie
M. Scott Doerrie
