- To: Pierre-Marie P�drot <pierremarie.pedrot AT ens-lyon.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Dependent types and equality
- Date: Thu, 30 Sep 2010 23:53:16 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=gmM+xzqD33k/b1Ul1p+gUl/VazTsEkfWyd1uQeKlQSwdWLQ8wbjVv8V3XJVMAs9Xzd lot+kUAAnQ7b2oAjkvfCqlyh/uDg3Wg7By2CKC1YbFToAWfmYmCNakcYBvWGcEd26e8n GKR+JszzoTOmC0xEje/IpVPhcrDVzw2vkROD0=
Hi,
Here is a (v8.3rc1) proof script that exploits the results from
Eqdep_dec and the fact that eq is decidable on nat:
Require Import Eqdep.
Require Import Eqdep_dec.
Inductive Fin : nat -> Type :=
| Fin0 : forall n, Fin (S n)
| FinS : forall n, Fin n -> Fin (S n).
Lemma Fin_eq_dec_aux: forall n x m y, {eq_dep nat Fin n x m
y}+{~eq_dep nat Fin n x m y}.
Proof.
induction x as [n|n x IHx]; intros m y.
destruct y as [m|m y].
destruct (eq_nat_dec n m) as [E|E].
subst. left. reflexivity.
right. intro F. inversion F. apply E. assumption.
destruct (IHx m y) as [E|E].
left. inversion E. subst. reflexivity.
right. intro F. apply E. inversion F. subst. reflexivity.
Qed.
Lemma Fin_eq_dec : forall n (x y : Fin n), {x = y} + {x <> y}.
Proof.
intros n x y.
destruct (Fin_eq_dec_aux n x n y) as [H|H].
left. apply (eq_dep_eq_dec eq_nat_dec). assumption.
right. intro F. apply H. rewrite F. reflexivity.
Qed.
Print Assumptions Fin_eq_dec.
Damien
Le 30 septembre 2010 22:54, Pierre-Marie Pédrot
a écrit :
> Dear Coq users,
> I've fighting for some days with equality and dependent types for very
> simple cases. I'm currently trying to fiddle with Fin, which defined as
> in CPDT :
> and I would like to find an axiom-free proof of decidability of equality
> for Fin :
> I have been unable to prove it without using JMeq axioms, and I did not
> succeed in proving it through hand-fed terms either. Yet, it works out
> of the box in Agda.
> Is there an axiom-free proof of this property, and what should it be ? I
> did not find anything relevant while skimming CPDT. Do you have any
> useful pointer ?
> PMP
- Re: [Coq-Club] Dependent types and equality, Damien Pous
- <Possible follow-ups>
- Re: [Coq-Club] Dependent types and equality, Laurent Théry
