- To: Ben Horsfall <ben.horsfall AT gmail.com>
- Cc: coq-club AT inria.fr, Harald Søndergaard <harald AT csse.unimelb.edu.au>
- Subject: Re: [Coq-Club] Type checking in the presence of fixpoints on type indices
- Date: Tue, 26 Oct 2010 08:06:57 -0400
Ben Horsfall wrote:
Suppose I'm trying to define an inductive relation on terms that have
an indexed type (i.e. Inductive tm : ty -> Set), and I have also
defined some Fixpoints f, g (let's say of type ty -> ty for
simplicity). Suppose also that I know that f x == g y (decidable
equality). Is there a way to induce the type checker to unify types tm
(f x) and tm (g y)? This should not require the fixpoints to be
computed during type-checking, only judicious use of a known equality.
Or is there a better way to approach this kind of difficulty?
Coq's type theory definitely doesn't support this. I don't know the details of your problem, but it's possible you could get the result you desire just by adding explicit equality premises to some constructors of some inductive definitions.
I'm dubious about the broader idea, though, since, even if we put off your question about type-checking convenience, I don't believe [f x == g y -> tm (f x) = tm (g y)] will be provable, in general, for an arbitrary [==]. Almost no equalities between types are provable in Coq, beyond those where the two types are syntactically equal. Perhaps if you added an _axiom_ justifying the inference you want, you would be able to use the Program feature to queue up equality statements that you could then discharge with the axiom. I don't understand Coq metatheory well enough to give conditions under which such an axiom would be consistent.
- [Coq-Club] Type checking in the presence of fixpoints on type indices, Ben Horsfall
- Re: [Coq-Club] Type checking in the presence of fixpoints on type indices, Adam Chlipala
