- To: staecker <cstaecker AT fairfield.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] function definition (easy?)
- Date: Thu, 28 Oct 2010 09:51:24 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=BV8fTJoPTFlXR2nP5OootxjQHceMbgmwao9GIAm6JCWohckvmmfrtqwDVdvHNod8+n Essf/EadJJamOfM0yEPBtIFO5GhFuBJNymiMFPhx3qITuACBnrYZ1wc4d4J2PSb/b/nf 5C6fULowu/dk8LSHt61FHzYtIDJMzmGJ+siqk=
Hi Chris,
To be able to write your function, you will need to posture that
equality on elements of your set V is decidable:
Parameter V_eq_dec : forall (v1 v2 : V), {v1 = v2} + {v1 <> v2}.
V_eq_dec is a function that, given two elements v1 and v2 of V, either
returns a proof that v1 is equal to v2 or returns a proof that v1 is
not equal to v2. You can use this function using a conditional
statement as follows if you don't care about the proofs:
Definition test (v1 v2 : V) : nat :=
if V_eq_dec v1 v2 then 1 else 2.
Hope that helps,
Edsko
On Thu, Oct 28, 2010 at 12:45 AM, staecker
wrote:
> Hi all-
> Sorry if this is an easy question. I hope there's an easy answer, but I
> can't
> figure it out.
> I have a datatype consisting of letters and letter-inverses taken from some
> set, defined like:
> Variable V:Set.
> Inductive Letter:Type :=
> | L : V -> Letter
> | Li : V -> Letter.
> Now I want a function which adds a letter to the front of a list, but
> cancels
> the letters if the newly added one is the inverse of the element on front.
> So:
> Reduce_cons (L a) (Li b :: L c :: nil) = L a :: Li b :: L a :: nil,
> and
> Reduce_cons (L a) (Li a :: L c :: nil) = L c :: nil.
> I'd originally written my function like this:
> Definition Reduce_cons (l:Letter) (w:Word):Word :=
> match l with
> L c => match w with
> Li c :: _ => tail w
> | _ => L c::w
> end
> | Li c => match w with
> L c :: _ => tail w
> | _ => Li c::w
> end
> end.
> But I realized that the pattern matching is treating the inner c's as new
> variables, so this doesn't work. (This would make Reduce_cons (L a) (Li b
> :: L
> c :: nil) = L c :: nil, which I don't want.)
> Any suggestions on defining this properly? I tried to do something with
> if/else, but I get confused working with bools vs Props. I want to say
> something like
> Reduce_cons l w :=
> match w with
> nil => l :: nil
> | b::bs => if (b = Linverse(l)) then bs else l::b::bs
> (where Linverse exchanges L for Li)
> But the above doesn't like the equal sign, wants a bool instead, and I don't
> know how to make that work.
> Thanks a lot-
> chris
- [Coq-Club] function definition (easy?), staecker
- Re: [Coq-Club] function definition (easy?), Edsko de Vries
- <Possible follow-ups>
- Re: [Coq-Club] function definition (easy?), Daniel Schepler
