coq-club - [Coq-Club] Ltac Determine if a variable is an existential
chronological Thread
  • From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Ltac Determine if a variable is an existential
  • Date: Fri, 5 Nov 2010 23:55:29 -0400
Hello,
Is there a way to determine if an Ltac variable binds a meta variable, i.e. a ?nn variable? In 8.2 and prior I had this Ltac definition:
Ltac meta X :=
  match X with
    | _ _ => fail 1
    | _ _ _ => fail 1
    | _ _ _ _ => fail 1
    | _ _ _ _ _ => fail 1
    | _ _ _ _ _ _ => fail 1
    | _ _ _ _ _ _ _ => fail 1
    | _ _ _ _ _ _ _ _ => fail 1
    | _ * _ => fail 1
    | X => fail 1
    | _ => idtac
  end.
Interestingly enough, terms with meta variables did not match themselves so all of the guards would fail until the end and the result would be a success. This behavior doesn't seem to work in 8.3 (possibly rightfully so), but is there another tactic that I can run?
Any pointers greatly appreciated. Thanks.
gregory malecha
