- To: coq-club AT inria.fr
- Subject: [Coq-Club] 8.3 Module Types and Module functor problems.
- Date: Tue, 30 Nov 2010 17:53:46 -0500
The following will type check in Coq 8.2 but not Coq 8.3. Something I don't understand is being lost in the definitions of module declarations.
Require Import OrderedType.
Require Import FMaps.
Module Type OT_inner <: OrderedType.
(* I need any module her. Normally, I would be using a functor, but any module will do. *)
Declare Module Inner : OrderedType.
Include OrderedType.OrderedType.
End OT_inner.
(* Module type copied excactly from FMap.Sord, only difference is input (X:OT_inner) *)
Module List_Sord2 (X:OT_inner) (D:OrderedType) <: FMapInterface.Sord with Module Data := D with Module MapS.E := X.
Module Inner := D.
Module Sord := (FMapList.Make_ord X D).
Include Sord.
(* produces error:
Error: The field Inner is missing in Top.List_Sord2.MapS.E.
However, the type of functor FMapList.Mak_ord <: Sord with Module Data := D with Module MapS.E := X.
X has field Inner. *)
End List_Sord2.
- [Coq-Club] 8.3 Module Types and Module functor problems., M. Scott Doerrie
