coq-club - [Coq-Club] Re: 8.3 Module Types and Module functor problems.
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Re: 8.3 Module Types and Module functor problems.
  • Date: Tue, 30 Nov 2010 18:34:36 -0500
To be clear, the code for 8.2 is slightly different. We can not declare a subtype on OT_inner since this is unsupported. "Include" must be changed to "Include Type" for compatibility.
Require Import OrderedType.
Require Import FMaps.
Module Type OT_inner.
(* I need any module her. Normally, I would be using a functor, but any module will do. *)
  Declare Module Inner : OrderedType.
  Include Type OrderedType.OrderedType.
End OT_inner.
(* Module type copied excactly from FMap.Sord, only difference is input (X:OT) *)
Module List_Sord2 (X:OT_inner) (D:OrderedType) <: FMapInterface.Sord with Module Data := D with Module MapS.E := X.
  Module Inner := D.
  Module Sord := (FMapList.Make_ord X D).
  Include Sord.
(* Produces no error*)
End List_Sord2.
On 11/30/2010 05:53 PM, M. Scott Doerrie wrote:
The following will type check in Coq 8.2 but not Coq 8.3. Something I don't understand is being lost in the definitions of module declarations.
Module Type OT_inner <: OrderedType.
  Include OrderedType.OrderedType.
End OT_inner.
(* Module type copied excactly from FMap.Sord, only difference is input (X:OT_inner) *)
  Module Inner := D.
  Include Sord.
(* produces error:
   Error: The field Inner is missing in Top.List_Sord2.MapS.E.
However, the type of functor FMapList.Mak_ord <: Sord with Module Data := D with Module MapS.E := X.
   X has field Inner. *)
End List_Sord2.
