- To: Hendrik Tews <tews AT os.inf.tu-dresden.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to work with multiple files?
- Date: Thu, 02 Dec 2010 09:02:37 -0500
Hendrik Tews wrote:
This is not too difficult. Just use a pseudo goal, which depends
on the real things. eg
buf1.pseudo: buf2.vo ...
and in buf1.v you include at the end
(*** Local Variables ***)
(*** compile-command: "make buf1.pseudo" ***)
(*** End: ***)
This solution has the drawback of forcing you to declare dependencies explicitly. I always use coq_makefile to calculate the dependencies, which is quite convenient.
In practice, what I do is run 'make' and stop when I see the file I'm working on start compiling. When there are long-running but unrelated jobs that would naturally run first, I make their long-running proof scripts 'Admitted', temporarily commenting out the real code. Clearly an ugly solution, but it gets the job done; niftier tool support would be welcome.
- [Coq-Club] How to work with multiple files?, Hendrik Tews
- Re: [Coq-Club] How to work with multiple files?,
Pierre Courtieu
Hendrik Tews
- Re: [Coq-Club] How to work with multiple files?, Adam Chlipala
Pierre Courtieu
- Re: [Coq-Club] How to work with multiple files?, Pierre Courtieu
- Re: [Coq-Club] How to work with multiple files?, Hendrik Tews
Pierre Courtieu
Hendrik Tews
Pierre Courtieu
