- To: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Anonymous signatures.
- Date: Thu, 09 Dec 2010 18:43:37 +0100
Le 08/12/2010 18:50, M. Scott Doerrie a écrit :
Each module has a signature. Is it possible to bind this signature to a
Module Type post-hoc? [...]
If you don't give an explicit signature, the "signature" of a module M is M itself. You must turn it into a "Module Type", though, if you want to use it as a signature. This can be done by using "Include":
Module Type MT.
Include M.
End MT.
But be aware that this "signature" keeps bodies of definitions (don't forget that there can be arbitrary terms in Coq's types). To use it in a useful way, there must be some abstract items (e.g. axioms, parameters) in M. There is no way AFAIK to make defined items abstract (except by giving an explicit signature that forgets them)... and keep in mind that the signature might even be not well typed if you forget all definitions.
Cheers,
Stéphane
- [Coq-Club] Anonymous signatures., M. Scott Doerrie
- Re: [Coq-Club] Anonymous signatures., Stéphane Glondu
