- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Interpretation of constructors of type forall
- Date: Mon, 13 Dec 2010 18:22:47 +0000
Dear Cedric,
Just to be clear, are you suggesting that the specification is
forall b : B, exists q : Q, rendition b q?
If so, how would you prove it?
Regards,
Jeff.
On 13/12/2010 14:32, AUGER Cedric wrote:
Le Mon, 13 Dec 2010 13:35:14 +0000,
Jeffrey
Terrell<jeff AT kc.com>
a écrit :
Dear Yves,You can do something like:
Thanks for your response. Yes, you are right. I *was* thinking of
process rather than property. I knew something was amiss but I wasn't
sure what it was.
What I'm essentially trying to do is to define the specification of a
mapping between a linked (i.e. ordered) list of Bs and a linked list
of Qs. For example:
b1 -> b2 -> b3
v v v
q1 -> q2 -> q3
b1 is mapped to q1
b2 is mapped to q2, and q1 is linked to q2
b3 is mapped to q3, and q2 is linked to q3
Links are represented as option types.
Inductive B : Set :=
Build_B : option B -> B.
Inductive Q : Set :=
Build_Q : option Q -> Q.
I'm actually more interested in the *specification* of this
transformation than its implementation:
Fixpoint X (b : B) : Q :=
match (R1 b) with |
None => Build_Q None |
Some b' => Build_Q (Some (X b'))
end.
Definition b3 : B := Build_B None.
Definition b2 : B := Build_B (Some b3).
Definition b1 : B := Build_B (Some b2).
Eval compute in (b1).
Eval compute in (X b1).
Is it possible to specify the transformation using an inductive
predicate, a sort of recursive rendition of
match (R1 b) with |
None => True |
Some b' => exists q' : Q, (Some q' = (S1 q) /\
match (R1 b') with |
None => True |
Some b'' => exists q'' : Q, (Some q'' = (S1
q') /\ ... ))?
(R1 and S1 return the option fields of objects of type B and Q
respectively.) I'm aware that this specification is process-oriented,
but I'm not sure how else to express it. Thanks.
Regards,
Jeff.
Inductive rendition : B -> Q -> Prop :=
| End_of_rendition: rendition (Build_B None) (Build_Q None)
| Rending: forall b q, rendition b q -> rendition (Build_B (Some b))
(Build_Q (Some q)).
By the way for such types, you may find useful to have:
Record B : Type := { R1: option B }.
then you can use b.(R1) instead of (R1 b), and {|R1 := Some b|} instead
of Build_B (Some b), so that you won't have to write the R1 function.
- [Coq-Club] Interpretation of constructors of type forall, Jeffrey Terrell
- Re: [Coq-Club] Interpretation of constructors of type forall,
bertot
Jeffrey Terrell
AUGER Cedric
- Re: [Coq-Club] Interpretation of constructors of type forall, Jeffrey Terrell
AUGER Cedric
Jeffrey Terrell
bertot
