coq-club - Re: [Coq-Club] why Prop appears?
chronological Thread
  • To: Loic Pottier <loic.pottier AT inria.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] why Prop appears?
  • Date: Tue, 14 Dec 2010 10:09:41 -0500
Loic Pottier wrote:
Inductive paths (T:Type)(t:T): T -> Type :=   idpath: paths _ t t.
Check (forall X:Type, paths _ X X).
returns
forall X : Type, paths Type X X
     : Prop
But I expected Type instead of Prop... where from does this Prop come???
I think this is the simulated universe polymorphism. Coq detects that your definition could just as well be put in [Prop], and doing so only increases the set of valid contexts where your type could be used. Thus, the change happens automatically.
With more involved type definitions, you'll get different universes based on choices of type parameters to the inductive family. Here, there is no such dependency, since you have only defined a single constructor with no arguments.
