- From: Daniel Schepler <dschepler AT scalable-networks.com>
- To: quanta AT sdf.lonestar.org
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Defining types from equivalence relations
- Date: Tue, 14 Dec 2010 12:34:21 -0800
- Organization: Scalable Networks
I've written a Quotient.v file which defines quotient types along with
induced
functions from quotient types. The main non-CiC axioms I use are
Extensionality_Ensembles, proof_irrelevance,
constructive_definite_description.
It depends on several other of my files, for things like declaring implicit
arguments in the Ensembles and Relation_Definitions libraries, defining a
notation for specifying an Ensemble as you'd specify a sigma-type, etc. If
you want I can send Quotient.v and its dependencies in either a zip or a tar.
{gz,bz2,xz,...} file.
The main idea is: define
Definition equiv_class (x:A) : Ensemble A :=
[ y:A | R x y ].
Definition equiv_classes : Ensemble (Ensemble A) :=
Im Full_set equiv_class.
Definition quotient : Type :=
{ S:Ensemble A | In equiv_classes S }.
Definition quotient_projection : A -> quotient.
refine (fun a:A => exist _ (equiv_class a) _).
Defined.
Now if you have f : A -> B satisfying
forall a1 a2:A, R a1 a2 -> f a1 = f a2
then you prove
forall abar:quotient, exists! b:B, exists a:A,
quotient_projection a = abar /\ f a = b.
Applying constructive_definite_description to this statement gives a function
forall abar:quotient, { b:B | exists a:A, quotient_projection a = abar /\ f a
= b }.
It's easy to derive the induced function fbar : quotient -> B from this, and
prove
forall a:A, fbar (quotient_projection a) = f a.
(I also provided variants for induced functions quotient R -> quotient S,
quotient R -> quotient S -> C, quotient R -> quotient S -> quotient T.)
Daniel Schepler
- Re: [Coq-Club] Defining types from equivalence relations, Daniel Schepler
