- To: coq-club AT inria.fr
- Subject: [Coq-Club] Memory usage
- Date: Thu, 16 Dec 2010 00:40:26 +0000
Hi all,
I'm having trouble with high memory usage. I've attached a
self-contained cut-down example that cann't be compiled in 900 MB:
$ ulimit -v 900000
$ time coqc z.v
Fatal error: out of memory.
coqc z.v 78.28s user 1.15s system 99% cpu 1:19.44 total
$ time coqc -dont-load-proofs z.v
Out of memory.
coqc -dont-load-proofs z.v 79.05s user 1.17s system 99% cpu 1:20.24 total
Essentially I have a datatype with 8 constructors, I dependently destruct
an entangled pair of them. This leaves only 17 of the 64 cases unsolved.
I admit the 17 cases and then try to save the proof.
Am I doing something silly? Is there a way to reduce the memory usage?
I have v8.3 (13693).
Thanks
Ian
Module Export z.
Require Import Equality.
Require Import List.
Parameter NameSet : Set.
Parameter SignedName : Set.
Parameter SignedNameSet : Set.
Parameter SignedNameSetIn : SignedName -> SignedNameSet -> Prop.
Parameter PatchType : NameSet -> NameSet -> Type.
Parameter pu_nameOf : forall {from to : NameSet},
PatchType from to -> SignedName.
Parameter commute : forall {from mid1 mid2 to : NameSet},
PatchType from mid1 -> PatchType mid1 to
-> PatchType from mid2 -> PatchType mid2 to -> Prop.
Parameter invert : forall {from to : NameSet}, PatchType from to -> PatchType
to from.
Notation "<< p , q >> <~> << q' , p' >>" := (commute p q q' p')
(at level 60, no associativity).
Inductive Sequence (from to : NameSet) : Type
:= Nil : Sequence from to
| Cons : forall {mid : NameSet}
(p : PatchType from mid)
(qs : Sequence mid to),
Sequence from to.
Implicit Arguments Nil [from to].
Implicit Arguments Cons [from mid to].
Notation "s :> t" := (Cons s t)
(at level 60, right associativity).
Notation "[]" := Nil
(no associativity).
Reserved Notation "<< ps >> <~~> << qs >>"
Inductive CommuteRelates {from to : NameSet}
: Sequence from to
-> Sequence from to
-> Prop
:= SwapNow : forall {op opq oq : NameSet}
{p : PatchType from op}
{q : PatchType op opq}
{q' : PatchType from oq}
{p' : PatchType oq opq}
{rs : Sequence opq to},
<<p, q>> <~> <<q', p'>>
-> <<p :> q :> rs>> <~~> <<q' :> p' :> rs>>
| SwapLater : forall {mid : NameSet}
{qs : Sequence mid to}
{rs : Sequence mid to},
CommuteRelates (from := mid) qs rs
-> CommuteRelates (p :> qs)
(p :> rs)
where "<< ps >> <~~> << qs >>"
:= (@CommuteRelates _ _ ps qs).
Reserved Notation "<< p >> <~~>* << q >>"
Inductive TransitiveCommuteRelates {from to : NameSet}
: Sequence from to
-> Sequence from to
-> Prop
:= Same : forall (s : Sequence from to),
TransitiveCommuteRelates s s
| Swap : forall {s : Sequence from to}
{t : Sequence from to}
{u : Sequence from to},
<<s>> <~~> <<t>>
-> <<t>> <~~>* <<u>>
-> <<s>> <~~>* <<u>>
where "<< p >> <~~>* << q >>"
:= (@TransitiveCommuteRelates _ _ p q).
Inductive ContextedPatch (from : NameSet)
: Type
:= MkContextedPatch : forall {mid to : NameSet}
(c : Sequence from mid)
(p : PatchType mid to),
ContextedPatch from.
Definition contextedPatch_name {from : NameSet}
(c : ContextedPatch from) : SignedName
:= match c with
| MkContextedPatch _ _ _ p => pu_nameOf p
end.
Axiom cheat : forall {a}, a.
Inductive CommutePast : forall {from mid : NameSet},
PatchType from mid
-> ContextedPatch mid
-> ContextedPatch from
-> Prop
:= CommutePastNil :
forall (from mid mid' to : NameSet)
(ident : PatchType mid to)
(ident' : PatchType from mid')
(p' : PatchType mid' to)
(H : <<p, ident>> <~> <<ident', p'>>),
CommutePast p
(MkContextedPatch _ [] ident)
(MkContextedPatch _ [] ident')
| CommutePastCons :
forall (o op opq opqr opqrs oq oqr oqrs : NameSet)
(p : PatchType o op)
(contextQ : PatchType op opq)
(contextRs : Sequence opq opqr)
(ident : PatchType opqr opqrs)
(contextQ' : PatchType o oq)
(contextRs' : Sequence oq oqr)
(ident' : PatchType oqr oqrs)
(p' : PatchType oq opq)
(H : CommutePast p'
(MkContextedPatch _ contextRs ident)
(MkContextedPatch _ contextRs' ident')),
CommutePast p
(MkContextedPatch _ (contextQ :> contextRs)
ident)
(MkContextedPatch _ (contextQ' :> contextRs')
ident').
Inductive CommuteManyPast : forall {from mid : NameSet},
Sequence from mid
-> Prop
:= CommuteNilPast : forall (from : NameSet)
(cp : ContextedPatch from),
CommuteManyPast [] cp cp
| CommuteConsPast : forall (o op opq : NameSet)
(qs : Sequence op opq)
(cp : ContextedPatch opq)
(cp' : ContextedPatch op)
(cp'' : ContextedPatch o)
(CommuteQsPast : CommuteManyPast qs cp cp')
(CommutePPast : CommutePast p cp' cp''),
CommuteManyPast (p :> qs) cp cp''.
Definition addToContext {from mid : NameSet}
(c : ContextedPatch mid)
:= cheat.
Parameter addSequenceToContext :
(ps : Sequence from mid)
(c : ContextedPatch mid),
Inductive Catch (from to : NameSet)
: Type
:= MkCatch : forall (p : PatchType from to),
Catch from to
| Conflictor : forall (effect : Sequence from to)
(conflicts : list (ContextedPatch to))
(ident : ContextedPatch to),
Catch from to.
Implicit Arguments MkCatch [from to].
Implicit Arguments Conflictor [from to].
Parameter invertSequence : forall {from to : NameSet}
(ps : Sequence from to),
Sequence to from.
Inductive commuteOneMany : forall {from mid1 mid2 to : NameSet}
(p : PatchType from mid1)
(qs : Sequence mid1 to )
(qs' : Sequence from mid2)
(p' : PatchType mid2 to),
Prop
:= commuteOneNil :
forall {o op : NameSet}
(p : PatchType o op),
commuteOneMany p [] [] p
| commuteOneCons :
forall {o op opq opqr oq oqr : NameSet}
(p'' : PatchType oqr opqr)
(q : PatchType op opq)
(q' : PatchType o oq)
(rs : Sequence opq opqr)
(rs' : Sequence oq oqr)
(pq_commute_q'p' : <<p, q>> <~> <<q', p'>>)
(p'qs_commute_qs'p'' : commuteOneMany p' rs rs' p''),
commuteOneMany p (q :> rs) (q' :> rs') p''.
Inductive commuteManyOne : forall {from mid1 mid2 to : NameSet}
(ps : Sequence from mid1 )
(q : PatchType mid1 to)
(q' : PatchType from mid2)
(ps' : Sequence mid2 to ),
Prop
:= commuteNilOne :
forall {o oq : NameSet}
(q : PatchType o oq),
commuteManyOne [] q q []
| commuteConsOne :
forall {o op opq opqr or opr : NameSet}
(p' : PatchType or opr)
(qs' : Sequence opr opqr)
(r : PatchType opq opqr)
(r' : PatchType op opr)
(r'' : PatchType o or)
(qsr_commute_r'qs' : commuteManyOne qs r r' qs')
(pr'_commute_r''p' : <<p, r'>> <~> <<r'', p'>>),
commuteManyOne (p :> qs) r r'' (p' :> qs').
Parameter sequenceCommute : forall {from mid mid' to : NameSet},
Sequence from mid ->
Sequence mid to ->
Sequence from mid' ->
Sequence mid' to ->
Prop.
Parameter conflictsWith : forall {from : NameSet},
ContextedPatch from ->
Prop.
Parameter conflictsNames : forall {from : NameSet}
(conflicts : list (ContextedPatch from)),
SignedNameSet.
Inductive CatchCommute1
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute1 :
forall {from to1 to2 : NameSet}
(p : PatchType from to1)
(q : PatchType from to2)
(namesDifferent : pu_nameOf p <> pu_nameOf q),
CatchCommute1 (MkCatch p)
(Conflictor ((invert p) :> [])
(cons (MkContextedPatch _ [] p) nil)
(MkContextedPatch _ [] q))
(MkCatch q)
(Conflictor ((invert q) :> [])
(cons (MkContextedPatch _ [] q) nil)
(MkContextedPatch _ (Nil(from := from))
p)).
Inductive CatchCommute2
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute2 :
forall {from mid to : NameSet}
(qEffect : Sequence mid to)
(qConflicts : list (ContextedPatch to))
(qIdentity : ContextedPatch to)
(qEffect' : Sequence from to)
(qConflicts' : list (ContextedPatch to))
(qIdentity' : ContextedPatch to)
(pEffect' : Sequence to to)
(pConflicts' : list (ContextedPatch to))
(pIdentity' : ContextedPatch to)
(namesDifferent : pu_nameOf p <> contextedPatch_name
qIdentity)
<<qEffect>> <~~>* <<invert p :> qEffect'>>
-> qConflicts = (MkContextedPatch _ (invertSequence qEffect') p) ::
qConflicts'
-> qIdentity' = qIdentity
-> pEffect' = []
-> pConflicts' = qIdentity :: nil
-> pIdentity' = MkContextedPatch _ (invertSequence qEffect') p
-> ~(qConflicts' = nil)
-> CatchCommute2 (MkCatch p)
(Conflictor qEffect
qConflicts
qIdentity)
(Conflictor qEffect'
qConflicts'
qIdentity')
(Conflictor pEffect'
pConflicts'
pIdentity').
Inductive CatchCommute3
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute3 :
(pEffect : Sequence from to)
(pConflicts : list (ContextedPatch to))
(pIdentity : ContextedPatch to)
(qEffect : Sequence to to)
(q' : PatchType from mid)
(pEffect' : Sequence mid to)
(namesDifferent : contextedPatch_name pIdentity <>
contextedPatch_name qIdentity)
qEffect = []
-> qConflicts = pIdentity :: nil
-> qIdentity = MkContextedPatch _ (invertSequence pEffect) q'
-> <<pEffect'>> <~~>* <<invert q' :> pEffect>>
-> pConflicts' = (MkContextedPatch _ (invertSequence pEffect) q') ::
pConflicts
-> pIdentity' = pIdentity
-> ~(pConflicts = nil)
-> CatchCommute3 (Conflictor pEffect
pConflicts
pIdentity)
(Conflictor qEffect
qConflicts
qIdentity)
(MkCatch q')
pConflicts'
pIdentity').
Notation "<< p , q >> <~>3 << q' , p' >>"
:= (CatchCommute3 p q q' p')
Inductive CatchCommute4
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute4 :
forall {o or ors orst ort : NameSet}
(pEffect : Sequence o ors)
(pConflicts : list (ContextedPatch ors))
(pIdentity : ContextedPatch ors)
(qEffect : Sequence ors orst)
(qConflicts : list (ContextedPatch orst))
(qOtherConflicts : list (ContextedPatch orst))
(qIdentity : ContextedPatch orst)
(qEffect' : Sequence o ort)
(qConflicts' : list (ContextedPatch ort))
(qIdentity' : ContextedPatch ort)
(pEffect' : Sequence ort orst)
(pConflicts' : list (ContextedPatch orst))
(pIdentity' : ContextedPatch orst)
(commonEffect : Sequence o or)
(pOnlyEffect : Sequence or ors)
(qOnlyEffect : Sequence or ort)
contextedPatch_name qIdentity),
qConflicts = addSequenceToContext (invertSequence qEffect)
pIdentity :: qOtherConflicts
-> qConflicts' = map (addSequenceToContext pEffect') qOtherConflicts
-> qIdentity' = addSequenceToContext pEffect' qIdentity
-> pConflicts' = qIdentity :: map (addSequenceToContext
(invertSequence qEffect)) pConflicts
-> pIdentity' = addSequenceToContext (invertSequence qEffect)
pIdentity
-> sequenceCommute pOnlyEffect qEffect qOnlyEffect pEffect'
-> CatchCommute4 (Conflictor pEffect
pConflicts
pIdentity)
(Conflictor qEffect
qConflicts
qIdentity)
qConflicts'
qIdentity')
pConflicts'
pIdentity').
Inductive CatchCommute5
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute5 :
commute p q q' p' ->
CatchCommute5 (MkCatch p) (MkCatch q) (MkCatch q') (MkCatch p').
Inductive CatchCommute6
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute6 :
(qEffect : Sequence mid1 to)
(qEffect' : Sequence from mid2)
(qConflicts' : list (ContextedPatch mid2))
(qIdentity' : ContextedPatch mid2)
qIdentity)
(noConflict : ~SignedNameSetIn (pu_nameOf p)
(conflictsNames qConflicts)),
commuteOneMany p qEffect qEffect' p' ->
CommutePast p' qIdentity qIdentity' ->
qConflicts' = map (addToContext p') qConflicts ->
~(qConflicts = nil) ->
CatchCommute6 (MkCatch p)
(Conflictor qEffect
qConflicts
qIdentity)
qConflicts'
qIdentity')
(MkCatch p').
Inductive CatchCommute7
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute7 :
(pEffect : Sequence from mid1)
(pConflicts : list (ContextedPatch mid1))
(pIdentity : ContextedPatch mid1)
(pEffect' : Sequence mid2 to)
pu_nameOf q),
commuteManyOne pEffect q q' pEffect' ->
CommutePast (invert q) pIdentity pIdentity' ->
pConflicts' = map (addToContext (invert q)) pConflicts ->
~(pConflicts = nil) ->
CatchCommute7 (Conflictor pEffect
pConflicts
pIdentity)
(MkCatch q)
(MkCatch q')
pConflicts'
pIdentity').
Inductive CatchCommute8
Catch from mid1
-> Catch mid1 to
-> Catch from mid2
-> Catch mid2 to
-> Prop
:= MkCatchCommute8 :
forall {from common mid1 mid2 to : NameSet}
(commonEffect : Sequence from common)
(pOnlyEffect : Sequence common mid1)
(qOnlyEffect : Sequence common mid2)
sequenceCommute pOnlyEffect qEffect qOnlyEffect pEffect' ->
CommuteManyPast (invertSequence qEffect) pIdentity pIdentity' ->
CommuteManyPast pEffect' qIdentity qIdentity' ->
pConflicts' = map (addSequenceToContext (invertSequence qEffect))
pConflicts ->
qConflicts' = map (addSequenceToContext pEffect') qConflicts ->
~(conflictsWith pIdentity (addSequenceToContext qEffect
qIdentity)) ->
CatchCommute8 (Conflictor pEffect
pConflicts
pIdentity)
(Conflictor qEffect
qConflicts
qIdentity)
qConflicts'
qIdentity')
pConflicts'
pIdentity').
(p : Catch from mid1)
(q : Catch mid1 to)
(q' : Catch from mid2)
(p' : Catch mid2 to)
: Prop
:= isCatchCommute1 : forall (catchCommuteDetails : CatchCommute1 p q q'
p'),
CatchCommute p q q' p'
| isCatchCommute2 : forall (catchCommuteDetails : CatchCommute2 p q q'
p'),
| isCatchCommute3 : forall (catchCommuteDetails : CatchCommute3 p q q'
p'),
| isCatchCommute4 : forall (catchCommuteDetails : CatchCommute4 p q q'
p'),
| isCatchCommute5 : forall (catchCommuteDetails : CatchCommute5 p q q'
p'),
| isCatchCommute6 : forall (catchCommuteDetails : CatchCommute6 p q q'
p'),
| isCatchCommute7 : forall (catchCommuteDetails : CatchCommute7 p q q'
p'),
| isCatchCommute8 : forall (catchCommuteDetails : CatchCommute8 p q q'
p'),
CatchCommute p q q' p'.
:= (CatchCommute p q q' p')
Lemma CatchCommuteConsistent1_3 :
forall {o op opq opqr opr oq oqr : NameSet}
{p1 : Catch o op}
{q1 : Catch op opq}
{r1 : Catch opq opqr}
{q2 : Catch opr opqr}
{r2 : Catch op opr}
{q3 : Catch o oq}
{r3 : Catch oq oqr}
{p3 : Catch oqr opqr}
{p5 : Catch oq opq}
(catchCommuteDetails : <<q1, r1>> <~>3 <<r2, q2>>)
(commute2 : <<p1, q1>> <~> <<q3, p5>>)
(commute3 : <<p5, r1>> <~> <<r3, p3>>),
(exists or : NameSet,
(exists r4 : Catch o or,
(exists q4 : Catch or oqr,
(exists p6 : Catch or opr,
<<q3, r3>> <~> <<r4, q4>> /\
<<p1, r2>> <~> <<r4, p6>> /\
<<p6, q2>> <~> <<q4, p3>>)))).
Proof with auto.
intros.
dependent destruction commute2;
dependent destruction commute3;
dependent destruction catchCommuteDetails;
dependent destruction catchCommuteDetails0;
dependent destruction catchCommuteDetails1.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
admit.
Qed.
End z.
- [Coq-Club] Memory usage, Ian Lynagh
- Re: [Coq-Club] Memory usage, Adam Chlipala
