- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Destructing dependent match
- Date: Thu, 16 Dec 2010 12:26:10 +0100
Oh, and just a precision, if you need something that depends on the
value of Z, in that case the hypothesis H1, make sure you assert it in
the context before clearing Z's body.
Stéphane
2010/12/16 Stéphane Lescuyer
<stephane.lescuyer AT inria.fr>:
> You need to first remove (or more precisely abstract) the part which
> fails to typecheck when (f x) is generalized:
> Goal forall x, P (
> (if f x as b return (f x = b -> A) then fun H => A1 x H else fun _ => A2)
> (refl_equal (f x))).
> Proof.
> intros x.
> set (Z := A1 x) in *; clearbody Z.
> destruct (f x).
> Notice how after the second line, the type of the first branch and its
> relation with (f x) is in the hypothesis, which allows the subsequent
> destruct to work.
> Cheers,
> Stéphane
> On Thu, Dec 16, 2010 at 11:38 AM, Guillaume Melquiond
>Â <guillaume.melquiond AT inria.fr>
> wrote:
>> Hi,
>> I'm having some trouble handling matchs when they have a dependent
>> return type. Below is a simplified example. I would like to perform a
>> case analysis on (f x) in order to simplify the goal. Ideally, that
>> would produce two goals, one of them being:
>> x: nat
>> H: f x = true
>> P (A1 x H)
>> Standard tactics aren't helpful. I also tried writing a complete proof
>> term, but I didn't succeed. Does anyone know of a tactic doing this kind
>> of job or a way to write the proof term?
>> Variable f : nat -> bool.
>> Inductive A :=
>> | A1 : forall x, f x = true -> A
>> | A2 : A.
>> Variable P : A -> Prop.
>> Hypothesis H1: forall x (H: f x = true), P (A1 x H).
>> Hypothesis H2: P A2.
>> Goal forall x, P (
>> intros x.
>> (*case (f x).*)
>> Best regards,
>> Guillaume
> I'm the kind of guy that until it happens, I won't worry about it. -
> R.H. RoY05, MVP06
R.H. RoY05, MVP06
- [Coq-Club] Destructing dependent match, Guillaume Melquiond
- Re: [Coq-Club] Destructing dependent match, Matthieu Sozeau
Stéphane Lescuyer
- Re: [Coq-Club] Destructing dependent match, Stéphane Lescuyer
Guillaume Melquiond
- Re: [Coq-Club] Destructing dependent match, AUGER Cedric
