coq-club - Re: [Coq-Club] Problem with setoid_rewrite and PER
chronological Thread
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Problem with setoid_rewrite and PER
  • Date: Mon, 20 Dec 2010 20:11:17 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=content-type:mime-version:subject:from:in-reply-to:date :content-transfer-encoding:message-id:references:to:x-mailer; b=qMO/hyXn1qu24GW37y5dycFGFsP7spp1s8+hTNdaK5X1H8ZyP7hywmhqoNF1TMxJ2G P9fhn2ZBU2hCkw7pETNBassG53jIKmy8BqyyqNO65gU8NBh9MP5CA2q/6RyOvGRDdKg9 CoWplVR+Y9LKuUpiIkiZmw5aBNjTTvf8gGiZw=
Le 20 déc. 2010 à 19:33, Andrew Kennedy a écrit :
> Hi all
Hi Andrew,
> I'm formalizing some basic algebra over carriers that are represented by a
> partial equivalence relation on a type, giving me a "subdomain" and an
> equivalence not fixed to Leibniz equality. But I'm having trouble getting
> setoid_rewrite to work: I can apply the "morphism" property directly, but
> setoid_rewrite fails. Here's a cut-down example:
> Require Import RelationClasses.
> Require Import Equivalence.
> Open Scope equiv_scope.
> Class SemiGroup {A:Type} {R} (sg_PER: PER R)  `(op: A -> A -> A) :=
> { ass : forall x y z, x =~= x -> y =~= y -> z =~= z -> op x (op y z) =~= op
> (op x y) z;
>  mor : forall x x' y y', x =~= x' -> y =~= y' -> op x y =~= op x' y'
> Require Import Setoid. Require Import Morphisms.
> Add Parametric Morphism {A} `(SemiGroup A) : (op) with signature R ==> R
> ==> R as g_op_morphism.
> Proof. intros x x' xx' y y' yy'. apply mor; assumption. Qed.
> Lemma boring: forall A `(SG: SemiGroup A), forall x y z, z =~= z -> x =~= y
> -> op x z =~= op y z.
> Proof. intros. setoid_rewrite H.
> At this point, I get a "tactic failure: setoid rewrite failed: unable to
> satisfy the rewriting constraints".  This despite the following explicit
> use of g_op_morphism working:
> Proof. intros. apply (g_op_morphism _ _ _ _ _ _ _ H0 _ _ H). Qed.
> Possibly I haven't set up the morphisms correctly.
> Any help very much appreciated!
It's precisely that: the fact that [z] is a proper element for [pequiv] in
your example
should be added as another morphism instance declaration. One way is to
[change (z =~= z) to (Proper pequiv z)] in this case, or to directly extend
the resolution tactic to try applying
reflexivity hypotheses:
Hint Extern 4 (Proper ?R ?z) =>
  match goal with H : R z z |- _ => eapply H end : typeclass_instances.
Beware that [PER] refers to something in [Relation_Definitions] after you
import [Setoid] and [Morphisms].
Cheers,
-- Matthieu
