- To: Thomas Schilling <nominolo AT googlemail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem with definition from CPDT
- Date: Tue, 15 Feb 2011 08:26:17 -0500
Thomas Schilling wrote:
I'm working through Adam's Certified Programming with Dependent Types and Coq
fails to accept the following definition from the book:
Is this a limitation of my version of Coq? I'm using Coq 8.2pl1 (latest on
MacPorts). Or am I missing something obvious?
The book is only tested with Coq 8.2pl2 and 8.3pl1. There were definitely some bugs in 8.2pl1 that prevented some of the code from type-checking, though I don't remember seeing your particular example mentioned before.
- [Coq-Club] Problem with definition from CPDT, Thomas Schilling
- Re: [Coq-Club] Problem with definition from CPDT, Adam Chlipala
- Re: [Coq-Club] Problem with definition from CPDT, Thomas Schilling
