- To: Adam Chlipala <adam AT chlipala.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "match (Zpos p?=0%Z) with ..." given "p : positive"
- Date: Thu, 17 Feb 2011 18:24:46 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=RgW9v+2RgBdZINdieDl+T0ZWoyyA27xhGCDIZwRWiakzHL4YMHUEZbXNBS6ZxKeVB/ mchuTtsHSTGna0IWdOWl5DG/f9T64uI2f7Du8pGgeJkNLfxNW7WyL/ak82kRBwGNiaAT s/OwlV1z3hNMQikvNK545cYN046dF4rbYDL2c=
Actually, the structure of goal looks like:
(Zpos p * a_formula))%Z =
a_function
match (Zpos p ?=0)%Z with
| Eq => ...
| Lt => ...
| Gt ==> a_value
end
After "Simpl.", it changes to:
match (a_formula)%Z with
| 0%Z => 0%Z
| Zpos y' => Zpos (p * y')
| Zneg y' => Zneg (p * y')
end =
(a_function a_value)%Z
But i do not know if a_formula is Zpos or Zneg or 0, i would expect a tactic such that it changes the goal to
Is it possible?
Thanks and regards
Tie
On Thu, Feb 17, 2011 at 5:56 PM, Adam Chlipala <adam AT chlipala.net> wrote:
Tie Cheng wrote:I would expect [simpl] to do the job.
I have "p : positive" in hypothsis and "match (Zpos p?=0%Z) with | Eq => ... | Gt => ... | Lt => ..." as part of the goal. Is there a tactic to remove the "match" from the goal?
- [Coq-Club] "match (Zpos p?=0%Z) with ..." given "p : positive", Tie Cheng
- Re: [Coq-Club] "match (Zpos p?=0%Z) with ..." given "p : positive",
Adam Chlipala
- Re: [Coq-Club] "match (Zpos p?=0%Z) with ..." given "p : positive", Tie Cheng
- Re: [Coq-Club] "match (Zpos p?=0%Z) with ..." given "p : positive", Andreas Abel
Adam Chlipala
