coq-club - Re: [Coq-Club] use the hypothesis "(a ?=0)%Z = Eq"
chronological Thread
  • To: Stéphane Lescuyer <stephane.lescuyer AT inria.fr>
  • Cc: Viktor Vafeiadis <viktor AT mpi-sws.org>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] use the hypothesis "(a ?=0)%Z = Eq"
  • Date: Thu, 17 Feb 2011 22:45:20 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=rlxSYm4aYgMIz6wybAWUOWZn2N7JCzn0gcDtalpBugGw1HkQdxgNjlFoHSmbC9mv9k MYwOhJafamb6Pz7cseAOonceh0km7KIJwoeGnzOzuAersIhSJwxpouKmN6Ixd8VRF3Vf C3YQIe7BGZZ2rixHoF7up0lUUDhJwZdvxnprQ=
Effectively "destruct a; try discriminate e." works. Thank you all.
Tie
2011/2/17 Stéphane Lescuyer <stephane.lescuyer AT inria.fr>
The comparison on Z is computational, and the equality test in your
hypothesis e will fail as soon as a starts with a constructor other
than Z0.
So you can simply destruct a, remove two of the three resulting cases
by contradiction and the only one that remains has a replaced by 0 :
If you are unsure about lemmas, it's sometimes good to go back to definitions :)
Hope this helps
Stéphane
On Thu, Feb 17, 2011 at 10:31 PM, Tie Cheng <chengtie AT gmail.com> wrote:
> Hello Viktor,
> Thanks for your reply.
> If I do "apply Zcompare_Eq_eq", it changes the goal to "(a * something
> ?=0)%Z = Eq" which is not what I want. I want the goal to be "(0 *
> something)%Z = 0%Z". Is there a better way to use Zcompare_Eq_eq?
> Regards
> Tie
> On Thu, Feb 17, 2011 at 9:25 PM, Viktor Vafeiadis <viktor AT mpi-sws.org>
> wrote:
>> Second lemma in Zcompare standard library.
>> Zcompare_Eq_eq
>> On 17 Feb 2011, at 21:20, Tie Cheng <chengtie AT gmail.com> wrote:
>> > hello all,
>> > I have a hypothesis "e: (a ?=0)%Z = Eq", my goal is " (a * something)%Z
>> > = 0%Z".
>> > Does anyone know how I could use the hypothesis? Is there a lemma to say
>> > "(a ?=0)%Z = Eq -> a=0%Z"?
>> > Thanks and regards
>> > Tie
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
