coq-club - Re: [Coq-Club] Beginner's Coinduction Question
chronological Thread
  • To: dimiter.milushev AT cs.kuleuven.be
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Beginner's Coinduction Question
  • Date: Fri, 25 Feb 2011 16:19:58 -0500
 wrote:
I am trying to do some very basic coinductive proofs in Coq,
but I get stuck and am not able to use the cofix tactic in lemma wfExStr
below.
CoInductive wf (t : Tree) : Prop :=
   wftree : forall f,
   t = Node f
   ->  inhabited f
   ->  (forall a ta, f a = Some ta ->  wf ta)
   ->  wf t.
Lemma wfExStr: forall X : Tree, exists w,
wf(X)->  elem w X.
This is a variant of a standard question about coinduction in Coq. Last time someone asked it, I said it was impossible to prove such theorems. That is, coinduction can only be used to build values of coinductive types, and you are trying to build a value of an inductive type (via [exists]), with a coinductive value nested inside.
Last time, however, someone suggested some scary (to me) solution that uses a very non-constructive axiom (if I remember correctly). Someone else may repeat the suggestion again soon.
