- From: Dimiter Milushev <Dimiter.Milushev AT cs.kuleuven.be>
- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem applying the coinduction hypothesis
- Date: Wed, 9 Mar 2011 13:38:45 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=u+B4NLr3z0qFta1NHw5XQOgxRCrE2IPzyqoEzX3UAPg5qsFISCMV4WmQcp/ryHZHfp 8mdCBoV1GZ+si0u3DDlMq80UaMJahb5PL1C+Tp4i1uYPclQP7krOPWeCTdnHkyfLMzoD mTnJiLXTW9LWYkY5GgUN6tJEbOpPwx/4+ONe8=
Cedric,
thank you very much! I owe you ;)
On Wed, Mar 9, 2011 at 12:30 AM, AUGER Cedric
wrote:
> Le Tue, 8 Mar 2011 13:47:08 +0100,
>Â dimiter.milushev AT cs.kuleuven.be
> a écrit :
> I have rewritten some minor parts to have simpler (but equivalent and
> keeping the same signature) definitions, but if you understand the
> proof, you should be able to have one with your definitions.
> The "Critical" proof has been completely rewritten, without trying to
> follow the one you did, so you may get lost, and some of your
> technical facilities may become useless, or may be used to simplify my
> proof.
> Require Import Coq.Lists.Streams.
> Set Implicit Arguments.
> Require Import Setoid.
> Parameter A : Set.
> Parameter f : A -> A.
> CoInductive Tree : Set :=
> | Node : (A -> option Tree) -> Tree.
> Inductive inhabited (f : A -> option Tree) : Prop :=
> inhabited_intro: forall a t, f a = Some t -> inhabited f.
> CoInductive wf: Tree -> Prop :=
> wftree : forall f,
> inhabited f
> -> (forall a ta, f a = Some ta -> wf ta)
> -> wf (Node f).
> Inductive derv (a: A): Tree -> Tree -> Prop :=
> derva : forall (f: A -> option Tree) (tx : Tree),
> f a = Some tx -> derv a (Node f) tx.
> Lemma wfsubtree : forall t a ta, wf t -> derv a t ta -> wf ta.
> Proof.
> Admitted.
> CoInductive elem : Stream A -> Tree -> Prop :=
> el: forall w : Stream A, forall X X' : Tree, forall a : A,
> derv a X X' ->
> elem w X' ->
> elem (Cons a w) X.
> (* Some Helpers *)
> Lemma elem_cons: forall (X Xa: Tree) (a : A) (w : Stream A), derv a X
> Xa -> (elem (Cons a w) X <-> elem w Xa).
> Proof.
> Admitted.
> Lemma elem2derv : forall a w X,
> elem (Cons a w) X -> exists Xa, derv a X Xa.
> Proof.
> Admitted.
> CoInductive IPP : Tree -> Tree -> Prop :=
> Tpp : forall X Y,
> (forall a : A, forall Xa, derv a X Xa
> -> (exists Yb, derv (f a) Y Yb /\ IPP Xa Yb))
> -> IPP X Y.
> Definition fIPP (P :Tree -> Tree -> Prop) (X Y : Tree) : Prop :=
> -> (exists Yb, derv (f a) Y Yb /\ P Xa Yb)).
> Lemma IPPunfold : forall X Y, IPP X Y <-> fIPP IPP X Y.
> Proof.
> Admitted.
> CoFixpoint fl (s : Stream A) : Stream A:=
> match s with Cons h t => Cons (f h) (fl t) end.
> Definition wfHP (X:Tree) (Y:Tree) : Prop:=
> wf X -> wf Y -> forall x, elem x X -> elem (fl x) Y.
> (* Technicalities to get the proofs done *)
> Definition SS (s : Stream A) :=
> match s with
> | Cons x t => Cons x t
> end.
> Lemma SSid : forall s:Stream A, s = SS s.
> Proof.
> intros.
> destruct s.
> reflexivity.
> Qed.
> Lemma Crucial : forall X Y : Tree, forall x,
> wf X -> wf Y -> IPP X Y -> elem x X -> elem (fl x) Y.
> Proof.
> intros.
> revert X x H2 Y H1 H H0.
> cofix CoindHyp.
> intros _ _ [s X X' a Ha Hs].
> intros Y HIPP; revert X Y HIPP Ha.
> intros _ _ [X Y H] Ha.
> generalize (H a X' Ha); clear H.
> intros [Y' [Ha' HIPP]] wfX wfY.
> cut (Cons (f a) (fl s) = fl (Cons a s)).
> intros [].
> split with Y'; auto.
> cut (forall A A' a, derv a A A' -> wf A -> wf A').
> intro H.
> apply CoindHyp with X'; auto.
> clear -wfX Ha H.
> exact (H X X' a Ha wfX).
> clear -wfY Ha' H.
> exact (H Y Y' (f a) Ha' wfY).
> clear.
> intros _ _ a [f A'].
> intros Heq H.
> inversion_clear H.
> exact (H1 a A' Heq).
> clear.
> change (let (b, c) := fl (Cons a s) in Cons b c = fl (Cons a s)).
> destruct (fl (Cons a s)).
> split.
> Qed.
- [Coq-Club] Problem applying the coinduction hypothesis, dimiter . milushev
- Re: [Coq-Club] Problem applying the coinduction hypothesis,
AUGER Cedric
- Re: [Coq-Club] Problem applying the coinduction hypothesis, Dimiter Milushev
AUGER Cedric
