- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Unification problem with type classes (substructures)
- Date: Thu, 10 Mar 2011 15:22:32 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:from:date:x-google-sender-auth:message-id :subject:to:content-type; b=riIzncZnt9cc3JXiSWXXjIw+3U+I6OaVGxMS80Sb/LBdWQQBK9Udb2vDDdNTQK99i1 g0zxMT1JOjOkOEDR2qkG+tF10op3GXe5fAQRApgz0maYXvJ0bScTLXMG8YklrDJC3Uuu jmY1VL52aO7hqBdKRXa5iDuaXci15jHXs1TXM=
Dear list
I'm using coq 8.3-pl1
(* Suppose I have a type class for almost monad *)
Class Monadish (M:Type -> Type) :=
bind: forall {A B :Type}, M A -> (A -> M B) -> M B.
(*And a type class for monad, that encapsulate the first (in real
code, it has more, but lets keep it simpl) *)
Class Monad (M:Type -> Type) := {
Monad_Monadish :> Monadish M
(* I can statethat option is a monad *)
Instance Monad_option: Monad option :=
Monad_Monadish := fun _ _ oa f =>
match oa with
| None => None
| Some a => f a
end
(* and I can prove lemmas with one bind *)
Goal (bind (Some O) (fun n => Some n) = Some O).
compute. reflexivity. Qed.
(* or two binds *)
Goal (bind (Some O) (fun n => bind (Some n) (fun x => Some x)) = Some O).
(* now let us pollute things with a second monadish *)
Inductive box (A:Type) : Type :=
| BOX: A -> box A.
Instance Monadish_box: Monadish box:=
{ bind := fun A B ba f =>
match ba with BOX a => f a end}.
(* the first lemma still works fine *)
(* the second fails ! *)
(* Error: Impossible to unify "option ?649" with "?645 ?647". *)
(* but if I add a specific instance for monadish option, even *before*
defining the one for box, everything works again *)
(*Instance Monadish_option: Monadish option.
eauto with typeclass_instances.
Defined.*)
Is this a known problem?
Cheers
Alexandre
- [Coq-Club] Unification problem with type classes (substructures), Alexandre Pilkiewicz
- Re: [Coq-Club] Unification problem with type classes (substructures),
Matthieu Sozeau
- Re: [Coq-Club] Unification problem with type classes (substructures), Alexandre Pilkiewicz
Matthieu Sozeau
