coq-club - [Coq-Club] Guidelines
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Guidelines
  • Date: Mon, 21 Mar 2011 11:33:41 +0100
First of all, sorry for the bad manipulation with mails.
(I thought that changing the title of a post was sufficient to have a
new thread and that only heuristics, like appending a "Re: " or
something like that allowed the mail viewer to put it in the same
thread).
So I start with a really new thread (what follows are the contents of
my previous post; and thanks to Zoli to signal it to me).
About the type conventions, I would like to know your point of view
with this:
Is it better to have:
(1) ∀ A B, P A → Q B → R
or:
(2) ∀ A, P A → ∀ B, Q B → R
A lot of people use (1), but I have always found (2) better, in
particular in combination with "Set Implicit Arguments.".
(There could also be the Higher order point of view
 "(λ B· (1) A B PA): ∀ B, Q B → R" is not as nice as
 "(2) A PA: ∀ B, Q B → R";
 but it is versus:
 "(1) A B: P A → Q B → R" which is nicer than
 "λ PA· (2) A PA B: P A → Q B → R"
 I happen to use the first case more often, so it gives me another
 advantage of this order.)
Same things appear for constructors:
Inductive R: Prop :=
R_intro:  ∀ A B, P A → Q B → R.
versus
R_intro: ∀ A, P A → ∀ B, Q B → R.
I also think that most of the tactics work better with the (2) form
than with the (1), since there are some cases where "B" must be guessed
in (1).
So if I would add something to guidelines I would also add the (1) form;
but I think most people prefer to add the dependant parameters first
(there is a "forall" less to type, and people prefer to introduce all
the general context first).
