coq-club - [Coq-Club] Help with proof
chronological Thread
  • From: Jeffrey Terrell <jeff AT abstractsolutions.co.uk>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Help with proof
  • Date: Sat, 26 Mar 2011 11:18:32 +0000
Hi,
I'd be grateful for some help in proving T. I'm aware that the outer "match" is redundant but would like to retain it for the time being. Thanks.
Regards,
Jeff.
(* A source class. *)
Inductive C : Type :=
   Build_C : forall _ : Set, option C -> C.
(* A target class, with pre and post conditions. *)
Inductive D : Type :=
   Build_D : forall S : Set, forall T : Set,
      (S -> Prop) -> (S -> T -> Prop) -> option D -> D.
(* The relation "source class is transformed into target class". *)
Inductive Pot : C -> D -> Type :=
Leaf :
   forall S : Set,
   forall T : Set,
   forall Pre : (S -> Prop),
   forall Post : (S -> T -> Prop),
      Pot (Build_C S None) (Build_D S T Pre Post None) |
Branch :
   forall c : C,
   forall d : D,
      Pot c d ->
         forall S : Set,
         forall T : Set,
            Pot (Build_C S (Some c)) (Build_D S T Pre Post (Some d)).
(* The specification of a transformation between a source and a
target class. *)
Fixpoint Tran (c : C) (d : D) (p : Pot c d) {struct p} : Prop :=
   match p with |
      Leaf S' T Pre Post =>
         forall s : S', Pre s -> exists t : T, Post s t |
      Branch c' d' p' S' T Pre Post =>
         forall s : S', Pre s -> exists t : T, Post s t /\ Tran c' d' p'
   end.
(* All transformations are provable. *)
Theorem T :
   forall c : C,
   forall d : D,
   forall p : Pot c d,
      match c with Build_C _ _ =>
         match d with Build_D S' T Pre Post _ =>
            forall Proof : (forall s : S', Pre s -> exists t : T, Post s t),
               Tran c d p
         end
      end.
Proof.
intros.
induction p.
simpl.
trivial.
simpl.
intros.
destruct (Proof s H).
exists x.
split.
assumption.
