- To: coq-club AT inria.fr
- Cc: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- Subject: Re: [Coq-Club] Destruct vs. inversion
- Date: Wed, 6 Apr 2011 10:36:44 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=Da+hal91zObXXHjQzmOY0mSfWsQeLs+rTLQ7+e41G15hphIPYINxrJBL8SumbeffbX w2hfJurgEtFmmBaCdjA3fo5vRApn0xXWeuHR2dBP9qm8x/h/yxphYRRVAaxlhEQ4RijM jUEQzPYpX7ue45qMaG7njjfIn6XblTelrKy0s=
On Wednesday 06 April 2011 09:50:29 Benjamin C. Pierce wrote:
> Dear Coq experts,
> Someone in my class asked a question about destruct vs. inversion: They can
> be described in similar terms ("generate subgoals for each of the
> possible ways that such-and-such could have been built..."), and there are
> many situations where either can be used; so what's the actual difference?
> Does anyone have a concise, intuitive way of explaining how they overlap in
> function and how they differ, and/or a snappy characterization of when to
> use one and when the other?
> Thanks!
> - Benjamin
inversion generates equalities and automatically does discriminate/injection
as appropriate, whereas destruct doesn't. My rule of thumb is: if the
inductive variables of the type are complex expressions, especially if they
involve constructors of that type, then I use inversion; otherwise, if
they're
all just variable names (or the complex ones don't really matter), I use
destruct. (Actually, it might be better just to try destruct first, and if
that doesn't generate enough context to continue, back up and use inversion
instead.)
An exception is when the goal contains something like "(foo (bar a b) c)"
where foo returns a subset type or something similar, then I tend to use
"destruct foo" to split out the value and the satisfaction hypothesis.
Daniel Schepler
- [Coq-Club] Destruct vs. inversion, Benjamin C. Pierce
- Re: [Coq-Club] Destruct vs. inversion, Daniel Schepler
- Re: [Coq-Club] Destruct vs. inversion, Nathan Collins
Guillaume Melquiond
- Re: [Coq-Club] Destruct vs. inversion, Jean-Francois Monin
Benjamin C. Pierce
- Re: [Coq-Club] Destruct vs. inversion, Jacques Garrigue
- Message not available
- Re: [Coq-Club] Destruct vs. inversion, Pierre Boutillier
- Re: [Coq-Club] Destruct vs. inversion, Paolo Herms
- <Possible follow-ups>
Daniel de Rauglaudre
- Re: [Coq-Club] Destruct vs. inversion, Chantal Keller
- Re: [Coq-Club] Destruct vs. inversion, Daniel de Rauglaudre
