coq-club - Re: [Coq-Club] Class Instances on the same type
chronological Thread
  • To: coq-club AT inria.fr
  • Cc: Matthieu Sozeau <mattam AT mattam.org>, Pierre Casteran <pierre.casteran AT labri.fr>
  • Subject: Re: [Coq-Club] Class Instances on the same type
  • Date: Mon, 11 Apr 2011 09:14:51 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=cwR3Jb9RJUWbZ2+qKypJmt3ii6f2cULhZieJeobBlDoPFVJE+dlKmyneoYEbQf9iCk f5WZlZfQKk/57C3fD4CIet2zJE5tSmUMbmkbYsrObHyWEl63SXwhtu100A9ocCM0+mNV 2j+UV0Wc82Fm26O3tgZd5pORMihCcf7l1m4nQ=
On Monday 11 April 2011 09:02:32 Matthieu Sozeau wrote:
> Le 11 avr. 2011 à 17:51, Pierre Casteran a écrit :
> > Hello,
> >  I define a class
> >   Class Monoid (A:Type) : Type := {
> >  dot : A -> A -> A;
> >  id : A;
> >  dot_assoc : forall x y z:A, dot x (dot y z)= dot (dot x y) z;
> >  id_left : forall x, dot id x = x;
> >  id_right : forall x, dot x id = x}.
> >   and build two instances on Z of class (Monoid Z)  : Z_add (additive
> >   monoid) and
> > Z_mult (multiplicative monoid).
> >  Is there a simple way to specify (locally or globally)  which of both
> >  instances can
> > be considered as the default one, when analyzing an undecorated  term
> > like for instance fun z:Z => dot z (dot z z)  ?
> Hi,
> You can specify different costs for the instances, and the matching
> instances of the lowest cost are applied first. This can only be set
> globally, at definition time (at least for now). The syntax is [Instance
> foo: Bar A | 10] where 10 is the cost.
> -- Matthieu
For local overriding of the default: for a one-shot thing, I believe you
could
use "fun z:Z => dot z (dot z z (Monoid:=Z_mult)) (Monoid:=Z_mult)".
And in a section, you might be able to do (untested):
Section use_mult_monoid.
Existing Instance Z_mult.
Let cube (z:Z) := dot z (dot z z).
End use_mult_monoid.
Daniel Schepler
