coq-club - Re: [Coq-Club] Haskell Extraction
chronological Thread
  • From: Trevor Elliott <awesomelyawesome AT gmail.com>
  • To: Pierre Letouzey <pierre.letouzey AT inria.fr>
  • Cc: Wouter Swierstra <w.swierstra AT cs.ru.nl>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Haskell Extraction
  • Date: Tue, 12 Apr 2011 12:27:22 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=tFKAALotzbK3DvUT3HuPt60o+tfEEkJCtV4soynfFLJ29g9Z5hnW6JgHveJwkv/jCc FtAY4KGKfdbKrJRmPIDm9szRz1sN5B8a+DffTstWRUhAAYsJ+SmmqDbE4LUGL53U+pzV tA/zRrdw2wGgQPKjHVwnL6HiMJaumhAd/bfIg=
Hi Everyone,
I think that my previous emails haven't really capured the problem that I've
been encountering, so I'm including a full example to describe the situation.
I would like to extract this function, defined in Coq, to Haskell, and get a
reasonably efficient implementation:
> Function example (a b c:nat) : nat := a*b + c.
For the sake of the example, I'm going to start off by extracting to OCaml.
> Extraction Language Ocaml.
> Recursive Extraction example.
This produces the following OCaml program:
> type nat =
>   | O
>   | S of nat
> (** val plus : nat -> nat -> nat **)
> let rec plus n m =
>   match n with
>     | O -> m
>     | S p -> S (plus p m)
> (** val mult : nat -> nat -> nat **)
> let rec mult n m =
>   match n with
>     | O -> O
>     | S p -> plus m (mult p m)
> (** val example : nat -> nat -> nat -> nat **)
> let example a b c =
>   plus (mult a b) c
I can make this version more efficient by importing the ExtrOcamlNatInt
module.
> Require Import ExtrOcamlNatInt.
This produces the following program that uses the native implementations of
multiplication and addition:
> (** val plus : int -> int -> int **)
> let rec plus = (+)
> (** val mult : int -> int -> int **)
> let rec mult = ( * )
> (** val example : int -> int -> int -> int **)
> let example a b c =
>   plus (mult a b) c
All of this works as I would expect.  The problems show up when I attempt to
repeat this process for extraction to Haskell.  Repeating the first step, I
can
extract the example function to Haskell, initially producing an inefficient
implementation:
> Extraction Language Haskell.
Produces this Haskell program:
> module Main where
> import qualified Prelude
> data Nat = 0
>          | S Nat
> plus :: Nat -> Nat -> Nat
> plus n m =
>   case n of
>     O -> m
>     S p -> S (plus p m)
> mult :: Nat -> Nat -> Nat
> mult n m =
>   case n of
>     O -> O
> example :: Nat -> Nat -> Nat -> Nat
> example a b c =
>   plus (mult a b) c
Adding Extract Constant for mult and plus should yield implementations of mult
and plus that look like:
> mult :: Prelude.Int -> Prelude.Int -> Prelude.Int
> mult  = (*)
I setup the extraction like this:
> Extract Constant mult => "(*)".
> Extract Constant plus => "(+)".
> Extract Inductive nat => "Prelude.Int" [ "0" "Prelude.succ" ]
>   "(\f0 fS n -> if n <= 0 then f0 () else fS (n-1))".
But the result looks much the same as the first time; the only difference is
that the resulting program lacks the definition of Nat.
> module Main where
> plus :: Prelude.Int -> Prelude.Int -> Prelude.Int
> plus n m =
>     (\_ -> m)
>     (\p -> Prelude.succ (plus p m))
>     n
> mult n m =
>     (\_ -> 0)
>     (\p -> plus m (mult p m))
>     n
> example :: Prelude.Int -> Prelude.Int -> Prelude.Int -> Prelude.Int
> example a b c =
>   plus (mult a b) c
So my main question is: how can I force the definitions of plus and mult to be
the ones that I supply with the Extract Constant command, producing Haskell
code that looks like the OCaml example?
Thanks,
--trevor
