- To: Vincent Siles <vincent.siles AT ens-lyon.org>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How to prove things about a function defined by accessibility
- Date: Mon, 18 Apr 2011 15:36:53 +0200
Hi Vincent,
Since Acc is in Prop, its _rect elimination principle is non dependent
by default. Here you need a dependent elimination principle. So you
can first do
Scheme Acc_rect_dep := Induction for Acc Sort Type.
then use "induction ha using Acc_rect_dep".
Hugo
On Mon, Apr 18, 2011 at 02:41:10PM +0200, Vincent Siles wrote:
> Hi everyone,
> I have defined a function by induction on an accessibility proof:
> Definition build_list : forall (l: list A),
> Acc R l -> P l -> list A.
> intros l h; induction h.
> <rest of the code>
> Defined.
> (P is just some precondition about l)
> Now I would like to prove things about build_list.
> I managed to do it *while* defining the list with:
> Definition build_list2 : forall (l: list A),
> Acc R l -> P l -> { k : list A | Q l k }.
> But I would like to do it in two times, with something like
> Lemma bl_Q : forall (l:list A) (ha: Acc R l) (hp: P l), Q l
> (build_list l ha hp).
> With this approach, if I try an "intros l ha; induction ha", I got an error:
> with Coq:
> "Error: Abstracting over the term "l" leads to a term
> "fun l : list A =>
> forall hp : P l, Q l (build_list_fun_acc ha hp)" which is ill-typed."
> with Ssr:
> "Error: ha is used in conclusion"
> Anyone knows a way to do such a separation between code & proofs ?
> Regards,
> Vincent
- [Coq-Club] How to prove things about a function defined by accessibility, Vincent Siles
- Re: [Coq-Club] How to prove things about a function defined by accessibility, Hugo Herbelin
